Hey All,
I've been working on this mill for a few months now and it's finally starting to come together. There are a couple more pieces I need before I can glue the sections (and remove those rubber bands) but once the pieces are done, this baby should be ready to make some chips (*fingers crossed!*)
I'm especially proud of where the spindle mounts to the Z axis. I made it out of one piece to include the spindle mount, the mount to the bearing, AND the acme nut. It's 3D printed from shapeways.com.
After the sections are glued/fastened together I will shoot some video of the machine sliding around on the bearings for everyone to see. However, I'm going to need a little bit of help getting the electronics working correctly as I'm trying a different (read: less expensive) setup than I have used in the past. If all works out as planned I will be driving the motors with 3 "easy driver v4" stepper controllers from Sparkfun (They should be delivered early next week). However, at this point I'm not sure how to get them up and running. I suppose we will cross that bridge when we get there.
So, the setup will be:
-8 wire steppers I bought from alltronics about a year ago
-Easy Driver v4 from Sparkfun
-Power supply? (I'm open for suggestions)
-EMC2
-CamBam
Here is the flicker feed of my new machine. I'd love to hear your thoughts on the design and any predictions as to where it might fail.The wood is lasercut 1/4" MDF.
Code:
