586,741 active members*
3,039 visitors online*
Results 1 to 9 of 9
    Jul 2009
    93
    Tool Wear Adjustment
    Hey all- so i have had my Haas VF-2 for a few months now and am trying to figure out where to put in for tool wear. I know on the offsets page it has a wear and geometry column. well i've put #'s in those columns and nothing has worked. see my problem is i have a brand new 1/4" end mill. well its cutting .005" big so i need to cheat it down to a .255" end mill. i thought you could just put a -.005" in the wear column and it would do that. I didn't know if you had to post a code in the program in order for it to work or what? i do my programs through bobcad so thats why i'm not sure how to cheat the tool offset. any help would be greatly appreciated.
    Thanks!!
    -Nate
    Mar 2009
    107
    It sounds like your program isn't using cutter compensation at all.
    Do you know how to hand code a cutter comp move with g41/42?
    Is your program calling the correct D#? (the Haas has a setting that will allow the tool h# and D# to be different)
    Mar 2008
    638
    If using cutter comp it would be +.005 to tell it that the tool is .005 larger.
    I use only the GEOM column per the Haas applications guy who showed us how to operate our VF-2SS.
    Jul 2010
    172
    Re: Tool Wear Adjustment
    nfrees114
    Hi-
    read your thread "Tool Wear Adjustment"
    Got the same problem--also using Bobcam-
    What was your solution??
    Thanks---- Rick
    Jul 2009
    93
    Quote Originally Posted by rckdef View Post
    nfrees114
    Hi-
    Thanks---- Rick
    Hey Rick- I had to post the code using a G41 offset instead of just a "left or right" offset. Then in the Haas offsets pages I just change the Geometry of the tool. I don't use the wear column, I just change the radius of the tool. So if it's a 1/4" End Mill and it's not cutting enough I'll change the radius of the 1/4" tool to .120 or whatever I need to get my size. Make any sense?
    -Nate
    Jul 2010
    172
    crabbass-
    could you explain the D# and H#--
    I think i know--but would rather be sure !!
    Thanks-- Rick
    Jul 2010
    172
    nfrees114-
    I think we are talking about the same thing-
    In Bobcam under compensation --i chose system compensation off
    and Machine compensation-Comp Left/G41
    I think that should have posted G41 in the code---but did not
    are we talking about the same thing?
    Thanks Rick
    Jul 2009
    93
    nfrees114-
    Thanks Rick
    Yep we're talking about the same thing! So you did change the system comp to a G41 and it's still not posting with a G41? Can you copy the code that it posts?
    Jul 2010
    172
    nfrees114
    Here Tiz
    (FIRST CUT - FIRST TOOL)
    (JOB 1 POCKET)
    (FEATURE POCKET)
    (TOOL #1 0.25 1/4 FLAT ENDMILL - LONG)
    N02 T1 M06
    N03 G90 G54 X0.1067 Y0. S1500 M03
    N04 G43 H1 D1 Z0.3 M08
    N05 Z0.1
    N06 G01 Z0. F5.1
    N07 X0.1711 Z-0.0034
    N08 X0.0622 Z-0.0091
    N09 X0.0607 Y-0.0139 Z-0.0098
    N10 X0.0561 Y-0.027 Z-0.0105
    N11 X0.0487 Y-0.0388 Z-0.0113
    N12 X0.0388 Y-0.0487 Z-0.012
    N13 X0.027 Y-0.0561 Z-0.0127
    N14 X0.0139 Y-0.0607 Z-0.0135
    N15 X0. Y-0.0622 Z-0.0142
    N16 X-0.0139 Y-0.0607 Z-0.0149
    N17 X-0.027 Y-0.0561 Z-0.
    Rick
  1. Replies: 2
    Last Post: 02-11-2014, 01:17 PM
  2. Replies: 7
    Last Post: 01-23-2013, 05:46 PM
  3. Tool Wear Compensation
    By rrbmachining in forum Haas Mills
    Last Post: 08-08-2011, 07:30 PM
  4. Compensating for Tool Wear
    By nfrees114 in forum BobCad-Cam
    Last Post: 02-26-2010, 12:59 AM
  5. tool wear indicater
    By Vern Smith in forum Haas Mills
    Last Post: 03-20-2007, 07:09 PM
