Hello,
Trying to get a G540 running and have a few questions:
1) The power LED is not lighting (but the fault LED is on RED). I assume the power LED should be on whenever the G540 has power (even if it's in fault). Is this true?
2) How can I determine which rev of the G540 I have? There is no serial number or rev number on the unit that I can see, but there is a hand-written "I9" on one end of the front panel. Also, there is a front-panel mounted charge pump slide switch, if that matters.
Thanks for any info.
- Steve
