586,375 active members*
3,506 visitors online*
Results 1 to 15 of 15
    Mar 2005
    18
    need help planning
    i am researching building my own cnc router and could use a little help
    i would like to see a machine about 4ft by 4ft
    i would mainly be cutting 3/4" soft wood
    it would be running a 2 or 3 hp router
    i would need a repeatability of around 1/32"
    speed up to as fast as the router could cut
    one of my biggest roadblocks is sizing the moters and ballscrew without being
    an engineer
    like saw for instance my gantry setup was 50lb?
    would i be ok with steppers or should i go with servos
    and how much would they cost
    i would like to keep this inside of $6000 or $7000 total
    i may be dreaming i dont't know?
    any and all help would be greatly apreciated
    thanks
    by the time
    Mar 2005
    21
    I am also in progression of the research phase to build my own cnc, therefore I might as well share my experience.
    I started by gathering as much information as I could, visited each and every site and compared different machines, read a lot of tutorials and white papers, joined a few yahoo groups and persued the threads closely, changed my design quite numerously.
    I found quite a lot of machines well thought and well designed which you could find them in this forum as well, but I came into this conclusion that I have to design it from scratch if I want it to be a fit-for-my-purpose, the hard way though, maybe even reinventing the wheel. But if feels good.
    Anyway through reading a lot of materials I am summing them up into an Excel spreadsheet which will be added to gradually. The first part will be the determination and selection of stepper motors which will be ready in a couple of days and I will send it to you (I don't know if there is a file submission folder for general use in CNCZone like those in Yahoo groups? If there is, please inform me). The second part would be lead screw sizing, which will happen afterwards.
    Since I intend to use Aluminum profile I have prepared a spreadsheet to calculate the deflection of different types and sizes under various loads, if it might help.
    Nader
    Dec 2004
    518
    Your not alone!
    Hi Russell. Lance here. I'm very much like you-in the planning stages. One thing I did early on was to scour this site and look at the specs on machines others are selling. Take the time and go back through some of the old threads-just about every question I came up with had already been asked-and answered.
    Gerry (Ger21) gave you a few links, but he pointed me to some pics of his machine that you may want to look at. He's done a good job making a very robust frame from wood. That is one way to keep the costs down.
    If your diligent and know what you are looking for you can make out well on eBay. Research finished auctions to see what a thingy usually goes for. Also to see how often they come up. Then find out what it is worth new! That $300 ball screw sounds like it's too much until you find out it was $3,000 new and only shows up about twice a year at auction. All of a sudden it looks like a bargain-if that's what you need.
    So is your $6,000-$7,000 machine a possibility? Just to give you an idea, here is what I've got in mine. I'll give you the actual prices I paid to date. I'm not trying to brag or show off, but to give you an honest appraisal of what you might be able to do.
    Router-Craftsman 2-1/4 hp 8,000 rpm to 27,000 rpm w 1/2" and 1/4" collets
    List $219, on sale for $199. Kept the router and currently trying to sell the case, fixed and plunge bases for $50. If successfull, $150 invested, new.
    One box of seven supposedly bad Baldor DC servo motors. Part numbers MTE 2240 BLBCN and 2250 BCBCN. Roughly 40-50 VDC bus, 20 amps, and 5000 rpm for the small 2240s, more for the 2250s. With tachometers and 100 PPR quadrature encoders. Mislabeled by Baldor-the small motors read 30 oz-in of stall torque. Should have been 30 lb-in! I paid $210 for all seven. Six had nothing wrong with them, number seven had one broken solder joint on the tachometer. I fixed it and it works fine. I'm going to keep them, but if I wanted I could keep just three for my machine and sell four. The 2250's today list for $1,000 new. So say $100 to $300 each on eBay. But without selling anything I'm up to $360.
    Three G320 step-direction Geckodrives for DC brushed servos: new from Mariss $114 each. So $342.00 for drives. Now I'm at $702.
    A complete slide unit with 5-6 inches of travel. This will be the Z axis. This came with THK rails, an NSK ground ball screw, built in limit switches, NEMA 23 motor mount, brushless servo motor and an RSR linear encoder. Bought two for $275. Motors were bad, everything else was good. Don't need the linear encoders, so I'll sell them for $75-$100 each. I could sell off the second slide for $100-$125. But assuming I don't, I'm up to $977.
    I wanted ground ball screws. Just because. I found some inadvertantly being sold as lead screws (much cheaper). Apparently no one else saw what they were-I got a 1-1/4" diameter ground ballscrew with 60" of threads, two coupled ball nuts, bearings, mounting blocks, and NEMA 42 motor mount for $300. He had more, so I picked up three others. The 50" long, 1" diameter ones were about $250. If I use one 50" and one 60" I'd be at $550 for screws. So $1,527 total.
    Slides for the X and Y axis. This probably doesn't apply as I got an absolutely fantastic deal. I picked up multiple sets of 80" long THK HSR 20mm rails with two HSR20-TR blocks each for $150 per pair. That isn't a realistic price. I sold the ones I didn't need for $200 per rail or $400 a pair. Even that is a good price. Since it is more in line with what one might pay on eBay, let's use the latter pricing. Two pairs of 6'-8" rails for $800. So our total is $2,327. Shorter rails are proportionally cheaper, as are the lesser quality grades (RSR, etc.)
    I still need a power supply for the servos. Haven't a clue, but $300 sounds about right (in reality I've got loose parts and will build my own-$0). Frame materials, wire, misc electrical parts, etc, and we might get to $3,000 even.
    Remember, I've got four extra servos and a slide I could sell off to lower this drastically.
    The PC I have, and Mach II software in demo mode is free-and that's a price you can't beat.
    Others will say I'm a fool and that a good machine can be built with less fancy parts. It's a matter of personal choice. Go with home made bearings, rolled ball screws/lead screws/rack and pinion and you can trim a ton. And if built well these can perform wonderfully.
    In my opinion you can get exactly what you want for much less than your projected budget-especially given the 1/32 repeatability and the reasonable dimensions. Bargain shopping time!
    Good luck and sorry if this was too long. I hope it helped.
    Lance
    I'd stay away from craftsman routers. For the same price Lance paid you can get a PC 892, which is a really nice router. But if your'e spending $6K-$7K, the smallest router I'd use is the PC 7518. A little more than $300. The next step up from that will be at least $2K
    Mar 2005
    18
    thanks for your help
    i was wondering where i would find these routers you are talking about
    Dec 2004
    518
    Unhappy PC = Porter Cable???
    Gerry,
    Ouch! My router = poo-poo? The selection in my town for routers was pathetic. My criteria was over 2 HP and variable speed. That was about all I could find.
    Can you elaborate a little on why the units you referenced are better? I may go for a return and upgrade. I take it that the "PC" is Porter-Cable, or am I all washed up there too?
    Any help is greatly appreciated. Thanks in advance.
    Lance
    Aug 2004
    2849
    The Hitachi router is 3 or 3 1/2 horsepower....I've got one and it's better then the PC. It's also nicely priced on Amazon.com....about $160 or so...last time I looked.
    Dec 2004
    518
    Router Wars!
    Thanks Viper. Have you actually used both to be able to say that the Hitachi is better? I'd ask you the same question I posed to Ger21: what makes one "better" than the other if the parameters like speed and power are the same. Conversely, what is to be avoided? (...well Lance, so long as you DON'T use the Craftsman, your fine...) Arghhh!
    Lance
    Correct me if I'm wrong, but the Hitachi is a plunge router, which makes it difficult to mount. The Porter Cable 7518 and a Milwaukee model are the only 3HP fixed base routers available in the US, I think.
    Lance, I don't buy Craftsman power tools. I haven't used one in a very long time, at least 10 years. They may be better now, but typically they just don't last as long.
    There is a Bosch and Makita that are comparable to the Porter Cable 892, but both cost a little more. And I happen to have 4 Porter Cable routers, so I stick with them.
    A friend has a Hitachi, and he likes it.
    I'd recommend the following brands at the top, not in order. Porter Cable, Bosch, Makita. I buy different brands for different types of tools. Makita cordless drill. Bosch jigsaw and belt sander, Porter Cable routers, laminate trimmers, and sanders. I have a Bosch laminate trimmer as well.
    Dewalt and Hitachi are pretty good, but I don't much experience with them. Do have a Dewalt 12" miter saw, though. It currently has a broken switch. Newer models have a redesigned switch.
    Was this any help, or just a bunch of rambling?
    Aug 2004
    2849
    Quote Originally Posted by Evodyne
    Lance
    Lance, yes I've used most of them at one time or another. I designed the first microprocessor based router for Craftsman back in the early 80's. What you find with of routers is that the universal motors that each uses are a bit different in characteristics and for under $200 Hitachi seems to be the best, we'll see in a few years of use how well they hold up. :wave:
    Dec 2004
    518
    Your advice is appreciated
    I'd like to thank you both for the very welcome advice. Like I alluded to before, the selection around here is poor, and, to be honest, I was in one of those "have to have something now" moods.
    After some thought, I think I'll keep the one I have for my "Phase I" temporary/disposable machine. Rationale? Learn how to get everthing working and when the inevitable crashes, thrashes, and flops occur I won't be so upset.
    But I am going to do a lot more looking for the "real" machine that comes next. Thanks again for your advice.
    Lance
    Feb 2005
    29
    Routers
    I would suggest you research the routers on a woodworking forum as they have an extended base or population over which to obtain the views required on the good, the bad and the ugly.
    Keep in mind with a plunge router for instance, it is already designed to be fitted into a holding mechanism.
    What does this mean to you?
    It means the chuck can be lowered and raised should the requirement be there.
    The fixed base are just that-fixed.
    If you extend the bit in its chuck to its outer limits, you invite vibration and wobble.
    A plunge router is very much like a laminate router, in my estimation, only it has a bigger, more complex base system.
    Woodworkers Journal, Wood and other wood working magazines are constantly evaluating various power equipement.
    Contact the magazines or research on the internet for the issue which has the various types of routers in them.
    I agree with Ger21 on Craftsman. They see a good design and then go to the manufacturer to have one made 'similar' only to their specs, and CHEAPER.
    For instance instead of ball bearings they may specify bronze bearings.
    From the outside two items may look alike-doesn't mean they are alike.
    As Sturm and Ruger said, let the buyer beware!
    JMHO
    DaveP kywoodwrkr
    Quote Originally Posted by kywoodwrkr
    Depends. With the 3-1/2HP Hitachi mentioned above, the motor can not be removed from the plunge base. This would not be an easy router to mount in a CNC. Most 2 1/2 HP and larger plunge routers are similar.
    2 HP and smaller, however are usually the round motor type, which can fit in either a fixed or plunge base, and which are the easiest to mount for CNC use.
    You should always put as much of the shank of the bit in the collet as possible. Fixed base routers are just as adjustable for depth as a plunge router, they are just fixed once the depth is set. For anyone that doesn't know this. NEVER bottom out the bit in a collet. You should always pull it back out about 1/8". If you push it all the way in, the collet may not be able to hold it properly.
    A plunge router is nothing like a laminate trimmer. A laminate trimmer is just a small fixed base router. It adjusts up and down the same way a fixed base router does, and is fixed in position once the depth is set.
    Imo, Fine Woodworking's reviews are the best. A lot of the other woodworking magazines tend to factor in price a bit too much in their decisions. I'd rather pay a little more for a better tool. Especially when you're talking about buying a router for a CNC, which will probably see far more use then the manufacturer intended for handheld use.
  1. Newbie questions. Planning a new machine.
    By space_case in forum DIY CNC Router Table Machines
    Last Post: 08-02-2005, 09:50 PM
  2. Newbie in planning stages
    By mb198007 in forum DIY CNC Router Table Machines
    Last Post: 04-23-2005, 01:57 AM
  3. Too much planning?
    By Hobbiest in forum DIY CNC Router Table Machines
    Last Post: 04-27-2004, 02:05 AM
  4. Proper Planning Prevents Poor Performance
    By CamIam in forum DIY CNC Router Table Machines
    Last Post: 04-01-2004, 02:09 PM
  5. modifying a drawing
    By Ken_Shea in forum OneCNC
    Last Post: 05-24-2003, 08:08 PM
