586,912 active members*
3,262 visitors online*
    Oct 2009
    bead blasting
    when i bead blast larger pieces i cannot get an even coat... any suggestions?
    Aug 2009
    13
    I'n not sure how big of a part you are talking about, but try doing just two passes, over and back, pretty quickly. Do the whole part this way and check your results, and go back over (the whole part) if needed. I haven't done this with bigger parts, but on smaller parts I have had issue with uneven blasting, the unevenness is magnified by anodizing.
  1. Making PCB with laser (no chemical etch)
    By RoboticsMD in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 11-07-2020, 10:25 AM
  2. CNC/Etch recommendations - high accuracy
    By MSEE-PHOTONICS in forum MetalWork Discussion
    Last Post: 08-21-2009, 03:13 PM
  3. Laser Etch Job
    By clembrant in forum Employment Opportunity
    Last Post: 04-08-2008, 07:17 PM
  4. Can you bead blast plastic?
    By MagTDK in forum Material Machining Solutions
    Last Post: 08-03-2007, 02:02 PM
  5. Giant Etch-a-Sketch?
    By SuperDeLuxe in forum DIY CNC Router Table Machines
    Last Post: 10-12-2006, 07:31 PM
