586,999 active members*
3,059 visitors online*
    Jul 2003
    12
    Servos and drive help
    Hi there guys, this is my first post ever on CNCZone .
    I am design my second router now, for this one i have decied to move to Servo motors. I have found some motors and their drives from a friend that I think would be suitable. Heres their data sheets:
    Motors : http://www.compumotor.com/manuals/Hauser/HDY_HJ.pdf (I have the HDY70C4-44S motor)
    Drives : http://www.hmkdirect.com/parker/Data...01000%20sl.pdf
    I have never used a servo system before, and I was hoping some of you guys might be able to help me.
    Basically what I wanted to know is wether this is all i need for them to run? (PC to Drive to Motor)
    Would i be able to control them with mach 2 ?
    I appreciate any help you can give me.
    Dave
    779
    I did not completely read the driver sheet, but in order to use Mach 2 the driver must accept Step and Direction pulses that come from the PC's printer port.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
    Jul 2003
    12
    Thanks for the reply,
    In the datasheet it says that i can recieved Step/ dir siginals, I assume this would be a serial connection on the Drive , would it be easy to interphase this to the parallel port on the pc Mach is controlling?
    If this would work is this all i would need to the control system?, i am asking this because i have heard of systems using a signal generator ( eg flashcut), what does this do.
    Dave
    6855
    Mach uses parallel port inputs.
  1. Using surplus servo motors as spindle drive
    By Swede in forum Servo Motors / Drives
    Last Post: 03-16-2008, 02:05 PM
  2. What all parts to convert cnc jr to servos?
    By blazer928 in forum Servo Motors / Drives
    Last Post: 11-15-2006, 08:01 PM
  3. Servos pausing and starting
    By InsaneEPP in forum Servo Drives
    Last Post: 03-16-2005, 03:45 AM
  4. Replacement servos, not sure what I need..
    By yukonho in forum Servo Motors / Drives
    Last Post: 01-03-2005, 11:56 PM
  5. Servos or Steppers..... and other gecko related questions
    By UKRobotics in forum Gecko Drives
    Last Post: 04-19-2004, 08:14 PM
