586,598 active members*
3,549 visitors online*
Results 1 to 7 of 7
    Mar 2005
    27
    Unhappy Milling with a Citizen C16
    Hello !
    I've got a big problem. Right now I'm trying to program a pocket on a Citizen C16 type IX.
    I'm working with the live tool position number T11.
    The size of the pocket is 6mm bright and 10mm long. The problem I have is this one. The brithness is right after the machining but the lenth and the raduis are wrong, to small why ?? The size of my tool is 3mm.
    M5
    G98 M58 S3=5000
    M28 S0
    T1100(MILLING POCKET)
    G0 X12.0 Y0. Z4.0 T11
    G19
    G1 X2.0 F80
    G42 Y3.0 Z4.0 F150
    G2 Y-3.0 Z4.0 R3.0
    G1 Z8.0
    G2 Y3.0 Z4.0 R3.0
    G1 Z4.0
    G2 Y-3.0 Z4.0 R3.0
    G1 Y0 G40
    G0 X12.0
    G18
    M60
    Do I still have to enter something under the tool data ??
    Please help
    304
    Try this, OR add size of tool to the "R" on the tool data page (P=0)
    M5
    G98 M58 S3=5000
    M28 S0
    G0 X12.0 Y0. Z6.0 T11(*****)
    G19
    G1 X2.0 F80
    G42 Y3.0 Z4.0 F150
    G2 Y-3.0 Z4.0 R3.0
    G1 Z11.0(*****)
    G2 Y3.0 Z11.0 R3.0(*******)
    G1 Z4.0
    G2 Y-3.0 Z4.0 R3.0
    G1 Y0 G40
    G0 X12.0
    G18
    M60
    Mar 2005
    27
    Still not working
    I tried both solutions and it's not working. If I had the R in the tool data page
    I get an alarm and if I change the program with the dimension you gave the radius is still wrong.......
    Why ??
    This is weird. I used to mill on the Fanuc CNC and I never got any problems
    304
    What alarm did you get? What is the radius coming out as?
    Mar 2005
    27
    Alarm P153 !!
    And I also tried to write 1.48 instat of 1.50 in my tool data !!
    Well I think this CNC is not as powerfull as Fanuc for milling. What I don't get is why is the size 6mm bright ok but the radius 3.0 is to flat ?? The G42 seems to be fine the lenght and all the points too.......... Maybe the CNC cannot find the right point when the tool radius and the radius in the program are the same !!
    Something is weird....
    304
    code
    The code below worked in my C16IX. This control is just TOO smart to accept any possible error. I had to convert to inch for my machine which gave me the following when converted back. I did not cut I just ran it through the motions and solved the alarms.
    (TDATA= R=1.4986 P=0)
    M5
    G98 M58 S3=5000
    M28 S0
    G0 X12.0 Y0. Z10.16 T11
    G19
    G1 X2.0 F80
    G42 Y3.0 Z5.9995 F150
    Z4.0
    G2 Y-3.0 Z4.0 R3.0
    G1 Z11.0
    G2 Y3.0 Z11.0 R3.0
    G1 Z4.0
    G2 Y-3.0 Z4.0 R3.0
    G1 Y0 G40
    G0 X12.0T0
    G18
    M60
    Mar 2005
    27
    Still searching !!
    Thanks for your help but it's still not working on my machine. Maybe the soft of my CNC is different. I'm looking further ....
    Cédric
  1. Thread milling, can anyone help
    By jtrav in forum Uncategorised CAM Discussion
    Last Post: 03-06-2006, 09:25 PM
  2. Why would this machine be bad for milling?
    By jevs in forum Knee Vertical Mills
    Last Post: 06-17-2005, 04:49 AM
  3. Heads Up - Article about building CNC Milling Machine
    By samualt in forum Community Club House
    Last Post: 06-13-2005, 08:43 PM
  4. CNC Drill driving the milling table
    By Com in forum Vertical Mill, Lathe Project Log
    Last Post: 04-04-2005, 09:27 PM
  5. power of milling motor
    By ML1 in forum Uncategorised MetalWorking Machines
    Last Post: 10-22-2004, 11:26 PM
