Pardon my ignorance, but I've been thrown into the fire, so to speak. I need to machine a pocket in 1018 material. The pocket is 1.3125 deep, 1.5 wide and is 6" long. The machine is a 35 taper vertical CNC. I've got a 1" dia. insert mill with 2 inserts. I started the job with 1.0469 drill bit. I drilled 4 holes and then milled the pocket with a 1" roughing endmill. Then finished with the 1" insert mill.
I know my feeds and speeds are wrong. I don't have the SFM for the insert mill. Is it true that the 1.0469 bit should have the RPM 292 with a feed of F4. ?? Is the machine not good enough to machine at this SFM? Any HELP would be much appreciated.
