586,588 active members*
2,500 visitors online*
IndustryArena Forum > CNC Electronics > Gecko Drives > Spindle Control Through G540
    Aug 2009
    42
    Can I use the fourth unused axis of my G540 to supply 0-10 volts to my Sieg X2 mini mill spindle? I would still need a relay to turn the motor on and off but will this work or not? Is there a downside to doing this or is there a better way to control the spindle motor with Mach3?
    Jul 2007
    1602
    Why not use the 0-10 volt analog output that is built into the G540?
    http://www.geckodrive.com/upload/G54...3%20MANUAL.pdf
    See item 10 on the first page.
  1. Has Anyone used G540 to control spindle speed on the X2?
    By Waldermac in forum Benchtop Machines
    Last Post: 02-08-2018, 03:46 PM
  2. G540 Spindle speed output voltage problem
    By georgef8 in forum Gecko Drives
    Last Post: 09-22-2009, 04:18 PM
  3. Gecko G540 and Coolant Control Relay
    By MrAR15 in forum Taig Mills / Lathes
    Last Post: 07-10-2009, 03:01 PM
  4. Geckodrive G540 Four Axis Control Bulk Pricing
    By CoAMarcus in forum News Announcements
    Last Post: 01-24-2009, 03:13 AM
  5. Replies: 0
    Last Post: 10-16-2007, 03:46 AM
