586,766 active members*
8,550 visitors online*
Thread: MAPPS
    Jan 2008
    575
    MAPPS
    How hard is it going to be for me to learn "MAPPS"?
    I know G&M code.
    I use MasterCam but the new job I am starting wants me to use MAPPS.
    So I was just wondering how hard it is going to be to pick up?
    Thanks, Robert
    Oct 2003
    352
    Mapps is not hard. I find that in order for you to do a program correctly you must really pay attention to the reference positions and origins. Your tool library must be set up correctly for accurate simulations/programs. Other than that, it does have its limitations but the simulation runs off of the G code so if you make a change to the program the simulation will change also. Changing the tool numbers in the programs screws everything up in the sim! If you are good at MasterCam, then Mapps should not be a problem. If you need specific help let me know.
    Jan 2008
    575
    Thanks WOLOG if I need some help I'll let you know.
  1. MAPPS CNC
    By sjh in forum Controller & Computer Solutions
    Last Post: 04-20-2009, 11:44 AM
  2. MAPPS Parameters for a Mori Seiki NL
    By tminnig in forum Fanuc
    Last Post: 09-30-2008, 10:57 PM
  3. Load meter / MAPPS parameter
    By Ugene96rs in forum DNC Problems and Solutions
    Last Post: 10-19-2007, 03:09 PM
  4. MAPPS question
    By RobinHood in forum Uncategorised MetalWorking Machines
    Last Post: 06-08-2007, 06:04 AM
