586,619 active members*
2,366 visitors online*
IndustryArena Forum > CAM Software > Vectric > VCarve Pro user needs Aspire user help
Results 1 to 11 of 11
    Mar 2009
    10
    I am a VCarve Pro user and love it. A friend has asked if I could carve a specific police badge for a service award. I have tried to convert a jpg image in VCarve, but it doesn't appear this will work out. Are there any Aspire users out there who would be willing to lend a hand and help me get a usable model? Thanks in advance.
    If you can't find any help here, try Vectric's forum.
    Jul 2007
    1602
    Check out this thread. It might do what you want.
    http://www.cnczone.com/forums/showthread.php?t=90009
    bob
    Sep 2007
    56
    Badge
    Ntww,
    Are you looking to do a 3d badge, or do you just need a clean 2d vector
    to vcarve?
    Aspire can trace the photo to get a 2d vector, but it is highly dependant on lighting, clarity, color ect as to how much "noise" the conversion will generate.
    S
    Mar 2009
    10
    Swain, 2D clean vector. I have both a color drawing of the image on the badge and a photo of an actual badge. The photo has way too many issues for a conversion. I have tried converting the drawing from the color version and from a grayscale version. When I do this with VCarvePro, I get a lot of noise that will take me something just short of forever to clean up. Don't know if it's just my technique or the limitation of VCP. I have made one pass at converting with the BOBCAD Art program (inherited when I purchased a used CNC but know nothing about). The BOB-ART appears to have two options (3D and Emboss). My feeble attempt at using it suggests the "emboss" option may have promise if I can figure out how to use it. Long answer to your question ... being just barely past "newbie" in CNC, I can't tell if my problem is software or technique. I suspect some conversion software is better than others and am hoping someone out there has a great conversion program and can lend a hand.
    Mar 2009
    10
    Here's the badge image I need to convert
    This is the color drawing of the badge in question.
    Oct 2006
    975
    Were you able to get toolpaths from the trace I did the other day? I was just cruising the Zone and saw this post and was hoping you have it all under control now? Let me know and I will try and help if needed.
    Wes
    Mar 2009
    10
    Badge
    Wes,
    Yes, your file will do what I need. Thanks again.
    NTWW
    Quote Originally Posted by metalworkz View Post
    Oct 2006
    975
    Good, I'm glad it is working for you. Maybe you can post a follow up with pictures when you finish it? It helps show what all is being done with the software!
    Wes
    Wes
    Jan 2006
    357
    Quote Originally Posted by ntww View Post
    Since you have bobcad you might want to watch the webinars they also have a channel on youtube, I don't know if you have to be a registered customer or not to view them.
    Sep 2007
    56
    Goofing off
    I decided to try this on yer badge...for fun...
    Take a look...not crisp and clean...but different
  1. Aspire 2 and VCarve Pro 5 Released!
    By Tony Mac in forum Vectric
    Last Post: 04-10-2010, 11:32 PM
  2. aspire, vcarve pro
    By cabnet636 in forum Commercial CNC Wood Routers
    Last Post: 03-16-2009, 10:56 PM
  3. new user
    By maMar in forum LinuxCNC (formerly EMC2)
    Last Post: 05-19-2007, 11:45 AM
  4. New user needs your help
    By Moondog in forum Mach Software (ArtSoft software)
    Last Post: 07-21-2004, 09:00 AM
