586,383 active members*
3,744 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > TL-1 door open alarm won't go off!
    Sep 2009
    10
    No matter what I do for whatever reason the door open alarm won't go off on our TL-1. Any ideas?
    Jul 2005
    12177
    The proximity detector may have a small chip sticking to it. It is on top of the headstock near the back where the shaft for the chuck guard is. When the guard is open a small metal tab comes down in front of the detector. (I think, I may have it backwards.)
    Sep 2009
    10
    When its open the chuck guard gets closer to it. Still about an 1/8 inch gap from touching it. Then when you lower the chuck guard there is a notched section that makes the gap closer to 3/8 of an inch. Is that right?
    Jul 2005
    12177
    I think so, is the end of the proximity detector clean? Any chips on it give the same effect as the when the guard is open.
    If that is clean are you pushing the little hand button thing that you are supposed to hold all the time for the machine to run?
    Sep 2009
    10
    I wasn't pushing the hand button!!!! Ugh.....I can't believe I fought that thing for that long and forgot the button! Thats what 12hr shifts does for you!
    Jul 2005
    12177
    Quote Originally Posted by donsbad89 View Post
    I agree, take some time off.
  1. OKK G4 tool change door open
    By dannystooblue in forum OKK
    Last Post: 09-18-2009, 02:26 PM
  2. Charmilles Robofil 300/310 Door Alarm
    By WIRE CUTTER in forum EDM Discussion General Topics
    Last Post: 07-26-2009, 12:34 AM
  3. kira vtc30a door won't open
    By nevron in forum Uncategorised MetalWorking Machines
    Last Post: 11-28-2008, 03:30 PM
  4. shutting down door alarm for mazak t plus
    By scott 54 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 12-14-2006, 02:27 AM
  5. Mini Mill door open alarm
    By paptep in forum Haas Mills
    Last Post: 11-21-2005, 10:31 PM
