586,465 active members*
3,678 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > Renishaw TS27R tool setter on HAAS machine.
    Feb 2009
    40
    Anybody using one of these? We have one that came on a Mini-Mill we purchased but have not messed with it. Are the worth the trouble to setup?
    Jason
    Mar 2009
    107
    Once you go probe, you won't go back.
    Do you like manually touching off your tools? Or would you rather just push a few buttons? In process length varification and other uses as well.
    For Instance...
    If you have a small center drill that you have problems breaking, so you stand at the machine to make sure it does fine, so the drill doesn't get smoked when it starts.
    with a tool probe, you could measure the center drill after it finishes, If it is broken the length will change and generate an alarm, If it is within your alarm limits Your cycle can continue on uninterupted (and unattended).
    Apr 2005
    713
    Jason, do a search here and all your questions will be answered.
  1. EC1600 - Renishaw TS27r
    By Ginger_Ninja54 in forum Haas Mills
    Last Post: 02-26-2009, 08:05 PM
  2. Protection for Renishaw Tool Setter
    By Gus-Gus in forum Haas Mills
    Last Post: 12-06-2008, 04:35 AM
  3. OTS Renishaw Tool setter help, Actually using it?
    By mgb1974 in forum Haas Mills
    Last Post: 06-02-2008, 02:54 PM
  4. OTS Renishaw Tool setter help
    Last Post: 03-18-2008, 12:19 PM
  5. Renishaw Tool Setter Mounting Position
    By HelicopterJohn in forum Haas Mills
    Last Post: 01-06-2008, 03:17 AM
