About Me
I graduated college with a B.S. in Mechanical Engineering about five years ago and was fortunate enough to find a job as an Engineer. One thing that surprised me about the job is how much actual "engineering" is not required. Most of the time I just plug numbers into a computer program and use what comes out. As you can see, I'm a little frustrated . To vent my engineering outlets I began designing, flying, and manufacturing Remote Control Aircraft. I moved into composite aircraft about two years ago and never looked back. It takes roughly 600-700 hours (depending on size) to make a male plug ready for production. After making a model (figures 1-3) I figured there had to be another way.....
About the Design
A friend of mine built a small MDF CNC machine and I was amazed at how fast it translated CAD models into reality. He suggested that I make one myself and use it for my business. I took all 5000+ hours of CAD experience and set out on my new mission. LET ME VERY CLEAR: I've never been a fan of MDF as a rigid construction material, but Aluminum :idea:. I found CNCZone and spent the next 1.5 years reading every thread I could and evaluating every design on here (thanks guys, this site is amazing). Some I liked, some I did not (i.e. not enough cutting area, MDF as the primary construction material, uses a wood router as spindle, etc). I really liked the Data-cut design, so I used it as a base and made quite a few modifications to suit my needs. Here's the base model (figure 4). These are all of the parts that require machining so I does not include bellows, spindle, enclosure, etc. The only problem was I had zero machining experience. My I first thought was to farm out the work; couldn't be that expensive right? WRONG, the lowest bid was $9,000+ for everything. I thought there had to be another way....
About My Shop
I started a thread (CLICK HERE) and bought a Seig X3 two years ago for the sole purpose of making the CNC router (figure 5). The X3 is outfitted it with the CNCfusion deluxe zero backlash kit and electronics gathered from Keling Inc. Total cost: ~$3000. Now I will have two machines when the project is over at a fraction of the cost :cheers:. It can hold a +/-0.002 tolerance easily so my machine should come out pretty well.
