586,796 active members*
4,025 visitors online*
Thread: Okuma lb15
    Nov 2007
    19
    Okuma lb15
    Can someone tell me if this lathe can operate in both axis at the same time?
    I am looking for something to make tapered threads.
    thanks
    Jan 2008
    575
    If that machine couldn't work on both axes at the same time it would be a paper weight, Just put the X and Z moves in the same line, but there are about 10 different ways (more complicated but simple enough) to do it.
    G1 X.5Z0
    X.75Z-1.5
    There you have a tapered pin
    And for the threads just use an I value
    Robert
    Nov 2007
    19
    Thanks a lot! I suspected it was capable of doing that , just needed confirmation.
    tony
    Apr 2006
    822
    If you know the "Included Angle" of the thread, use the "A" command within the G71 cycle. Where A is the included angle.
    If you are trying to correct taper in a thread, i.e. make a parallel thread, measure the diameter at each end of the thread and then set the amount of difference/2 in an I value. Obviously a positive value in I will increase the diameter at the end of the thread and a negative I value will reduce the thread diameter at the end of the thread.
    Be aware that the I value is an incremental value and is the amount of movement you require on RADIUS over the length of the thread.
    Cheers
    Brian
    Nov 2007
    19
    Thanks a lot Brian.Very useful information.
    Tony
  1. okuma LB15
    By NJC in forum Okuma
    Last Post: 04-11-2013, 05:40 AM
  2. I need IGF manual or pdf for okuma LB15
    By cncldwms in forum Okuma
    Last Post: 10-24-2012, 02:20 PM
  3. OKUMA LB15 reviews
    By WGJ in forum Okuma
    Last Post: 11-12-2009, 11:33 PM
  4. Okuma LB15 tailstock alignment
    By emfgllc in forum Okuma
    Last Post: 05-23-2009, 12:06 AM
