586,377 active members*
2,609 visitors online*
    Dec 2007
    15
    Cool Mach3 weird behaviour
    After four month normal working, my plasma table get weird. (I have THC also.)
    Cutting holes seems normal, but when it cuts straight lines, after about 10, 20... sec torch begins to raise slowly until arc gets off. During this time, led DOWN on THC is on, and torch goes UP!
    Any idea what causes this?
    How to diagnose where is the problem?
    mrpeja
    Dec 2007
    15
    I solved the problem!
    I have set max THC to 10 mm and min THC to 1 mm. But the sheet wasn't flat and when the torch references to higher area, and later comes to lower area, it can't go below 1 mm. When I set min THC to -5 mm, all is OK.
    So, the torch wasn't go slowly up, as I think. It can't go lower and torch voltage raises during lower parts of sheet, until arc go off.
    BTW, I made test adaptor to simulate plasma equipment (Arc good and Arc led ON). The purpose was to test THC according to THC300 manual, without using clips connected to PCB. At the first time the torch won't go up and down, until I shut off AntiDive button.
    I'm not sure if I need Antidive to be on or off.
    Please advice about AntiDive.
    P.S. excuse for my English
    mrpeja
  1. Mach3 Strange behaviour
    By wellbuiltcabs in forum Mach Software (ArtSoft software)
    Last Post: 01-31-2008, 02:48 AM
  2. Strange behaviour of 10T
    By guhl in forum Fanuc
    Last Post: 12-11-2007, 04:28 PM
  3. mach3 running xylotex 3axis weird problem
    By Claude Boudreau in forum Xylotex
    Last Post: 07-18-2007, 11:24 PM
  4. VMC 15-XT strange behaviour
    By FinnCNC in forum Fadal
    Last Post: 03-27-2007, 05:03 PM
