High-speed, high power and high rigidity make productivity improvements to be leaps and bounds. In the spindle torque, fast feed speed, positioning accuracy, covering the basic technical specifications are at advanced level. Through the exchange of advanced man-machine interface , simple MPG operation, making this the largest models to meet the needs of users. The new design brings the perfect ergonomic features, processing and space with the best flow of traffic and higher visibility. This new line of Rail series machines optimal performance, flexible best competitive prices. standard with 6000 rpm spindle speed. At the same time added a lubricating oil circuit system to protect your machine precision, extended service life.
-3.1 Inch single blue LCD display screen
-showing spindle speed and direction
-and movement size
-panel focused on manual control system
-cooling and spindle control
-800 X 250mm Size of table
-6000rpm/min High Speed Precision Spindle
-220V single-phase AC power supply
-MT3/SK30 metric or R8 imperial spindle
-1 x 120mm pre-installed high-speed
-cooling fan
-high quality casting materials,
-compact structure
-OEM PMI double nut ballscrews
-Hiwin precision linear guideways
-safety of high-quality electrical
-components and fast plug
-the integration of the base casting
-manual lubrication system pre-installed
-to protect the rail life
-pre-installed fourth axis interface
-MPG handwheel controller pre-installed
-pre-installed computer arm
-CE and CCC safety certification
China Mainland Global Headquarters/All OtherEnquiries
#20 FaoFan Road,Xiaodong Industry Zone.
Yuyao City.Zhejiang, China.
Phone:+86 (574)62735995 62735996 62735997 62735998
Fax: +86 (574)56664747
email: [email protected]
web: www.syil.com.cn
