586,452 active members*
3,156 visitors online*
    Jul 2003
    71
    Arrow 500 spindle module
    Does this require separate programming? I'm looking at a machine the owner says the spindle drive needs to be programmed. A2100 controls.
    Jan 2009
    9
    Hi JWC,
    Normally the spindal drive that is located in the back of the machine in the cabnet is set up parmeters for each machine and not changed! If the spindle drive has lost its parmeters you need to find out what they were and enter them this could be concidered programming but not in the normal sence. It is more concidered as a CNC Machine Tech fuction not a programmer.
    Be sure that you get the correct information on the issue sometimes it can be hard to find the exact parmeters based on how the machine was configured hopfully the owner has the parmeters hard copy.
    Good luck!
    CNC PRogramming, Inc.
    Matt
    Dec 2007
    159
    IIRC you can call Simens and they will send the info.We had this same problem on an Arrow last year.
    Jul 2003
    71
    That's what I thought Matt. I've had to enter the parameters on my Hurco BMC20 in the past. The way the Arrow owner described it made it sound like a major project.
    Thanks for the info.
    Wes
  1. 11M output module
    By hobiedude in forum Fanuc
    Last Post: 01-08-2008, 06:05 PM
  2. if you need ic and module,please tell me.
    By keithshen in forum Want To Buy...Need help!
    Last Post: 01-07-2008, 02:07 PM
  3. Lathe Module
    By rodneydeeeee in forum BobCad-Cam
    Last Post: 08-28-2007, 12:09 AM
  4. Please need help on I/O Module
    By yeager in forum CNC Machine Related Electronics
    Last Post: 01-13-2006, 03:19 PM
  5. Another learning module
    By Chunky in forum G-Code Programing
    Last Post: 06-11-2005, 11:04 AM
