586,345 active members*
3,284 visitors online*
IndustryArena Forum > MetalWorking > MetalWork Discussion > NPT Taper-to-Straight-to-NPT-Taper Thread
    Oct 2007
    30
    Smile NPT Taper-to-Straight-to-NPT-Taper Thread
    You're probably thinking "What is this guy talking about?"
    I have a job to tackle that is a bit different then the normal than just a NPT Taper thread or Straight Thread. A bit more complicated....... Want to see if anyone has tackled something similar.The job to make conduit for the electrical industry and they need something specific.
    Customer is asking for a 4" NPT Taper on 1st end of shaft that will continue threading to a 4" NPTS Straight Thread then back to a 4" NPT Taper for the other end of the shaft. The NPT Taper threads on each ends are standard engagment, but the main thing is to be able to thread a 4" NPTS straight thread coupling all the way across the entire shaft which is 7" O.A.L.
    You might ask....... "if using a 4" NPTS straight coupling, then why thread taper the ends?" Reason is because they still use a locknut inside the elect. boxes that need a handtight engagement.
    So.....
    1) I have chucking stock to be able to thread entire 7" length. I will set up using my tailstock on one end and 7 1/2" out of chuck for threading.
    2) I know I probably can't use a G76 cycle for this because of the amount of variables here. Probably have to use a G32 cycle if not mistaken.
    I have not written G32 cycles for threading in the lathe. Mostly G76
    2-line cycles for all threads. That is why I ask for some help.
    So program would have to start a G32-- 4" NPT Taper, then continue threading a 4" NPTS straight thread across the shaft, and lastly, another 4" NPT Taper thread downward to the end of 7" O.A.L of shaft.
    May 2007
    1003
    PM sent.
    Jul 2003
    1754
    I don't know what kind of machine you have...
    This is sort-of similar. (and probably a bit more complicated) But might give you some ideas.
    (emc2)
    http://jmkasunich.com/cgi-bin/blosxo...k/fusee-1.html
    [ame="http://www.youtube.com/watch?v=ACvRilmIKDQ"]YouTube - Variable Diameter/Variable Pitch ThreadCutting with EMC2[/ame]
  1. How to machine an adapter to convert taper shaft to straight
    By kola in forum MetalWork Discussion
    Last Post: 07-15-2011, 04:39 PM
  2. Thread Milling a Taper
    By automizer in forum G-Code Programing
    Last Post: 06-13-2008, 04:23 AM
  3. taper thread cutting
    By cncmc in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-05-2008, 10:59 AM
  4. taper thread
    By gcrandall in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-17-2006, 04:13 PM
  5. R8 taper
    By lt paul in forum Uncategorised MetalWorking Machines
    Last Post: 06-10-2004, 04:31 PM
