586,129 active members*
3,156 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > slow acceleration/deceleration fanuc OM
    Sep 2009
    Hi
    The machine I'm working on is a Yang machining-center with fanuc OM control, and it has REALLY slow spindle acceleration/deceleration.
    Does anybody know what parameters to change to make it faster?
    Aug 2007
    793
    There are no parameters in Fanuc 0, related to spindle acc/dec
    What type of spindle amplifier?
    See manual for it
    There should be needed parameters
    BTW, may be your spindle is in current limiting mode during acc/dec because of the large moment of inertia of mechanical load, for instance. Or any troubles with current detection circuit in amplifier
    Attached Files Attached Files
    Feb 2007
    314
    look a prm #6582 Acceleration/deceleration time setting standard setting is 10
    prm#6530 Soft start/stop time standard setting is 0 (i tried to change #6530 but with no effect and i never tried #6582)
    Aug 2007
    793
    Quote Originally Posted by samu View Post
    Strange, but I don't see these parameters in my manual
    The only acc/dec parameters related to spindle are parameters related to rigid tapping
    Oct 2008
    106
    Try the list of parameter as follow.
    6572 change from 900 to 3000
    6536 change from 0 to 200
    6537 change from 0 to 6000
    6583 change from 96 to 70
    6603 change from 400 to 200
    6611 change from 100 to 1000
    6630 change from 250 to 800
    it should work
    Ahn Vuong
    Aug 2007
    793
    Oh, I've understood
    These parameters are for @ series spindles
  1. Spindle turn slow(Tsugami - Fanuc 6T)
    By starn36 in forum Fanuc
    Last Post: 01-19-2012, 04:16 PM
  2. HELP! Fanuc 3m slow CW Spindle problem
    By SSMrob in forum Fanuc
    Last Post: 10-04-2011, 01:11 PM
  3. Fanuc 6M Slow Response Time
    By TR MFG in forum Fanuc
    Last Post: 09-03-2009, 09:15 PM
  4. Replies: 0
    Last Post: 07-31-2008, 10:35 AM
  5. acceleration/deceleration of masses
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-07-2005, 12:51 AM
