586,692 active members*
3,019 visitors online*
Results 1 to 7 of 7
    Apr 2003
    13
    Roughing end mills for aluminum?
    can anyone recommend a good roughing end mill for aluminum? i have been looking at the Minicut roughing/finishing end mills that Rutland sells. it says they're specifically for aluminum. has anyone used one of these before? are they worth the money?
    thanks,
    ben
    Apr 2003
    1876
    Re: Roughing end mills for aluminum?
    thanks,
    ben
    Hi, Ben.
    Like anything else, it will depend on a number of factors...
    [list=1][*]Type of Alum?[*]Machine stability/speed/feed[*]fixture stability[*]type of roughing, contour, pocket, surf etc[*]depth you need[/list=1]
    'Rekd teh more data please
    Apr 2003
    13
    hi rekd. i'm a novice, and i don't quite know how to answer your questions. i think i'll be working mostly with 6061 Al. i have a tiny sherline 5400 mill, which i use to make parts for my RC helicopters. i just need a good general purpose roughing end mill to make my work go a little faster.
    106
    Ben--
    I use the International Minicut on alot of the aluminum jobs we run. I use 1/2", 5/8" and 1" diameters. The ones with the polished flutes cost a bit more but is worth it. They evacuate the chips a bit better and don't load up. I'm not sure how much you can pull with your Sherline but these things will really hog out the material. For instance, I run the 1/2" cutter at 7640rpm and 85 inches per minute. Full width of cutter thru 3/4" aluminum and it just eats it up.
    One cutter that I like better is the SGS Ski-Carb. They are a little more expensive but I have run them at 10,000 rpms at 200 inchs and it cuts like butter. Regrinds are no good unless you let SGS do it because of their special geometry.
    Apr 2003
    13
    thanks, e-stop. i think i'll try one of the ones with the polished flutes.
    Apr 2003
    1876
    Sounds like many of the standard mills will work. You might consider the minicuts if the price is good. Dont' spend top dollar for performance EM's if your machine/applications don't warrent it. (For hobby stuff, the standard tooling will work just fine)
    'Rekd teh All this talk about homemade routers and mills makes me wanna makes me one.
    Matt
    San Diego, Ca
    ___ o o o_
    [l_,[_____],
    l---L - □lllllll□-
    ( )_) ( )_)--)_)
    May 2003
    146
    Rekd,
    I been thinkin teh same thing.
    Have you checked out some of the pics in the home made router threads ?
    looks like fun.
    Wee aim to please ... You aim to ... PLEASE.
  1. G-Code to DXF
    By WayneHill in forum OpenSource Software
    Last Post: 05-19-2021, 11:26 PM
  2. Visual Basic Controller Project
    By dwwright in forum Visual Basic
    Last Post: 04-16-2016, 10:31 AM
  3. End Mills and Sharpening
    By Robin in forum MetalWork Discussion
    Last Post: 04-09-2005, 02:33 AM
  4. End mill's? you ain't seen nothing yet
    By Ken_Shea in forum Community Club House
    Last Post: 09-02-2004, 04:13 AM
