586,701 active members*
2,625 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > ATC Problem Z- dont go up 3.8" just 35mm
    Aug 2009
    12
    Dear Boss,
    I have next problem: when i try change the tools the procedure is start well, but when the Z axis must be go up 3.8inch the machine is go to emergency mode.
    The z axis all time go up just 34-35mm and tools half in the spindle and half is in atc. The machine was resetted total (battery removed from cpu card)
    in setp menu i adjusted evrything . (i hope).
    air we have enough,
    Have u idea what was wrong?
    MAchine is fadal 3016l with cnc88 hs.
    The z servo was removed too .
    ThanksTomee
    Jul 2009
    317
    check switch inside tool in out assambly
    Aug 2009
    12
    i find the problem, it was one wrong settings in setp menu.
    Now its works fine.
    Re: ATC Problem Z- dont go up 3.8" just 35mm
    Hello Tomeeii
    I have the same problem, can you tell me what was your solution?
    Thank you
    Greetings.
    Aug 2009
    12
    Quote Originally Posted by dardo View Post
    Hello Tomeeii
    Thank you
    Greetings.
    Sure, it was wrong setting in setp menu.
    I will check for u what was. Here is my private email: [email protected]
    Send me your email.
  1. Gerwah DKN 15/26 6.00mm-6.35mm
    By derekj308 in forum Want To Buy...Need help!
    Last Post: 01-11-2013, 12:44 PM
  2. If i dont press "Reset" bottom at End, my stepper motors becoming really HOT
    By myhomeco in forum Mach Software (ArtSoft software)
    Last Post: 05-05-2011, 07:55 PM
  3. Turning Al 35mm rod to 25mm
    By chris123 in forum Benchtop Machines
    Last Post: 07-18-2010, 05:33 PM
  4. Where to buy 35mm Shafts?
    By LinearMotionFan in forum Want To Buy...Need help!
    Last Post: 12-12-2008, 06:34 AM
  5. 35mm rods (60" long) for X-axis gantry support
    By LinearMotionFan in forum Linear and Rotary Motion
    Last Post: 11-24-2008, 10:36 PM
