586,721 active members*
3,185 visitors online*
    May 2003
    325
    Lightbulb High resolution encoder
    Here's an idea for a cheap HiRes encoder.
    An inexpensive optical mouse can be had for US$ 10-20. An optical mouse has an inherent resolution of 400 dpi ( 0.0025" ).
    Machine a disk 3.183 inches in diameter. Fasten the disk to the end of your lead screw. Mount the mouse so that it reads the outside edge of the disk.
    The circumference of the disk is 10.00 inches. That will give you 4000 counts per revolution! Which with 10 tpi lead screws is 40,000 counts per inch! Or 0.000 025 inch resolution.
    This should be enough for the Tim Allen in everyone
    robotic regards,
    Tom
    p.s. or, if you machine the end of your lead screw to 0.3183 inches diameter, forget the disk and just read the screw surface for 4,000 counts per inch.
    T
    4826
    That is the germ of a good idea, but you need to be sure that the detector reads a known number of irregularities of the surface to get its count, do you not?
    May 2003
    325
    I have tried my optical mouse on every surface I can find including slick coated paper and 'clear' plastic. It works flawlessly on all except a mirror (although I haven't tried on steel). So if the surface finish is not too fine it should work.
    In the worst case, you might be able to get away with a piece of paper (or other suitably textured stuff) around the shaft or disk.
    But a bigger problem I see is getting just the pulses out of the mouse. By design the beasts encode x motion, y motion, and the switch closures into a serial data stream.
    robotic regards,
    Tom
    4826
    Post
    A lot of CAD programs will give some kind of coordinate output directly proportional to mouse movement.
    I'd have to try pushing an optical mouse using my cnc, to find out how repeatable it would be. I would find it surprising if the mouse would not "lose or stretch the distance" for a few pulses every once in a while, depending on the surface, which would be kind of irrelevant for normal mouse usage, but very relevant when using it as an encoder. It would be interesting to know.
    2139
    Buying an encoder for $26.00 would be easier.
    But not as fun.
    Eric
    I wish it wouldn't crash.
    Apr 2003
    307
    Hey, there's an answer for a low cost digitizer. Move your mill to a certain spot, drop a probe and read out a straight distance.
    Or use a $26 encoder connected to a probe as a rack and pinion.
    Chris
  1. encoder issues
    By rutexus in forum Servo Drives
    Last Post: 05-22-2006, 12:49 AM
  2. High Resolution Encoder Help
    By Donovan in forum Servo Motors / Drives
    Last Post: 02-13-2005, 04:05 PM
  3. Active High/Active Low
    By Sanghera in forum CNC Machine Related Electronics
    Last Post: 11-07-2004, 03:47 AM
  4. Need encoder recommendation
    By Swede in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2004, 02:01 AM
  5. Encoder wiring
    By balsaman in forum Gecko Drives
    Last Post: 12-30-2003, 06:01 PM
