586,956 active members*
3,001 visitors online*
Results 1 to 20 of 30
Threaded View
    2010
    Using Igus rails for 2nd build
    Skate bearings work but.............
    They constantly pick up cuttings in little wads, or break, or freeze up, or........... the list is endless.
    So I tried the 10mm Igus rail and bearing on one axis of my home built router ( see this thread http://www.cnczone.com/forums/showthread.php?t=57030) and was exceedingly pleased.
    They don't bind as I was told (at least not with my anti racking cable system in place) and they don't need lube nor do they collect crap.
    With all that I was seriously considering a re-build using Igus rails and discussing the possibilities with an old friend when he got this look on his face and he asked me how much room I had in my motor home. (I was traveling and visiting over the summer)
    He then showed me a sheet of aluminum and said that I need to take it home with me as he didn't have enough room in his shop. (Yeah, right!)
    Below is a picture of it. It is .750" X 24" X 32" and is anodized. Further discussion revealed thyat it had once been the base for a cnc machine used to manufacture medical products.
  1. Easy to build torsion box and rails
    By lgroulx200 in forum DIY CNC Router Table Machines
    Last Post: 11-21-2012, 06:37 PM
  2. Igus Rail
    By DDM in forum Linear and Rotary Motion
    Last Post: 01-17-2008, 09:26 PM
  3. Igus products
    By woodfish510 in forum Linear and Rotary Motion
    Last Post: 04-18-2007, 07:29 PM
  4. build help on alignment of leadscrew, rails etc
    By posix in forum DIY CNC Router Table Machines
    Last Post: 02-10-2006, 09:14 PM
  5. IGUS W Linear Rails
    By Kemper73 in forum Linear and Rotary Motion
    Last Post: 07-20-2005, 06:45 PM
