I am cutting with a 3/4" TIN 4 flute end mill. I origionally ran it at 2000rmp and have now reduced it to 1000 because I found aluminum attached to the endmill after a couple passes..
Coated cutters are not suitable for aluminum and four flute cutters often do not have enough chip clearance in the flutes so the chips get stuck. Try to get uncoated cutters two or three flute with a high helix in either HSS or Carbide for aluminum, and always use coolant/lubricant.
How are you approaching this? Making the notch down the side of the piece held in a vise?
If your machine can do either helical interpolation or subroutines you should be able to do this in less than ten program lines if the intersection between the two pieces of round bar has to be 90 degrees.
