586,398 active members*
3,114 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Lathes > success! big piece mounted and turning!
Results 1 to 1 of 1
    Mar 2006
    103
    Boy - recently had a few jobs come in that were huge (for me anyways! <grin>)
    Check out this photo I snapped of this piece of 4140 prehard.
    9" diameter - 12" length
    225 pounds of pure steel mounted in a Haas SL-30 with 10" chuck with tailstock.. I tell you it was scary prepping the hole for the tailstock.
    I put 300 psi on the chuck pressure just to be on the safe side. Is there a general rule on how much psi one should put based on weight of material?
    I used a fork lift with some lifting belts to mount the piece in the chuck - wasn't too bad at all!
    cheers!
    Paul
  1. Sketchup success in CNC?
    By ZipSnipe in forum Uncategorised CAM Discussion
    Last Post: 02-27-2011, 04:59 PM
  2. Success!!!!
    By Smitty911 in forum Benchtop Machines
    Last Post: 03-02-2008, 04:13 PM
  3. Success HX6090SE
    By pedroman in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 05-26-2007, 02:02 AM
  4. R2E3 success story
    By bkraz in forum Bridgeport / Hardinge Mills
    Last Post: 12-02-2005, 08:34 PM
  5. At Last, Success is Mine!
    By jstuedle in forum Community Club House
    Last Post: 07-07-2004, 03:26 AM
