586,312 active members*
3,212 visitors online*
    Feb 2004
    2337
    Need to do a 3d model of a horse.
    My 9 year old daughter ( Amelia ) is horse crazy. ( Comes with the age I guess)
    She has been hassling me to route her a horse plaque.
    My problem is I wouldnt know where to start. Does any one have any gcode of a horse that I can use?
    If you can upload it into this thread we would both appreciate it.
    Being outside the square !!!
    Not sure if this will work for you. I got it at 3DCafe. I converted it to .stl for you. You'll probably have to scale it up.
    Attached Files Attached Files
    779
    Here is a horse relief. It might be a bit hard to cut the true 3D horse. I can also get you a Pegasus.
    Jeff Davis (HomeCNC)
    http://www.homecnc.info
  1. Taking Delivery on Techno-Isel 4'x4' 130 Model
    By mtuckf in forum Commercial CNC Wood Routers
    Last Post: 03-23-2005, 03:20 PM
  2. 1/5 scale Model A engine
    By woodythx13 in forum I.C. Engines
    Last Post: 12-17-2004, 09:16 PM
  3. RFQ closed - scale model machined auto wheels needed
    By joemartins in forum Employment Opportunity
    Last Post: 10-27-2004, 02:16 PM
  4. Looking for someone to do 3-d model
    By seansear in forum Employment Opportunity
    Last Post: 08-13-2004, 09:39 PM
  5. Solid model to CNC code quession
    By mikenelson in forum Uncategorised CAM Discussion
    Last Post: 07-08-2003, 03:55 AM
