587,067 active members*
3,559 visitors online*
Results 1 to 7 of 7
    Aug 2009
    4
    Maho MH600E/Philips 432 toolchanger
    We install this machine and setup constant form some list.
    Does not works automatic toolchanger. Still error 185 "Tool in tool changer gripper".
    Where can be problem ? Must be some calibrated or set some constant ? Or is some dammaged ?
    Aug 2009
    4
    Solved.
    1) save data via RS232 from MH600E to notebook
    2) unplug batery for cca 1minute
    3) plug batery
    4) set manualy RS232 constants
    5) load saved data via RS232 to MH600E
    Aug 2009
    4
    Next problem - changing of tools works, but some suspicious.
    F.eg:
    are presented Tool 7 and Tool 13.
    1) is used Tool 7. Then is used Tool 13. But changer place Tool 7 back into position of Tool 13 and not into position of Tool 13. Why ?
    Does exist some manual, how must be set Tools constants ?
    Dec 2006
    7
    This is how this toolchanger works-- random access. If you look at the tool table there is a 'P' or position number for each tool. This is the position in the carosel that the tool occupies. The machine keeps track of where it takes tools from and where it puts them back- it will update the P value. The tool number does not have to correspond to the position in the carosel.
    Oct 2009
    Maho parameters
    I just bought a 1989 Maho MH600E, the batteries went down and all parameters are lost. Could you share the parameter list with me?
    Quote Originally Posted by sneebot View Post
    good day ..... the times of change the tools are changeable? because in my mh600e the change is slow
    Dec 2006
    7
    Re: Maho MH600E/Philips 432 toolchanger
    The Maho toolchanger is painfully slow. No way that I know of to speed it up.
  1. Maho MH600E - CNC432 Data transfer problems
    By Grusse in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 01-20-2021, 11:31 AM
  2. Maho MH600E Loading Constants Problem
    By Davey Boy in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-16-2013, 04:57 PM
  3. Maho MH600E Y axis Brake?
    Last Post: 03-15-2013, 09:33 PM
  4. Going for the Gold - Maho MH600E Conversion to Mach
    Last Post: 08-06-2012, 03:12 AM
  5. Maho MH600E Milling machine questions???
    By marx911 in forum Uncategorised MetalWorking Machines
    Last Post: 01-23-2009, 07:51 PM
