586,807 active members*
7,982 visitors online*
IndustryArena Forum > MetalWorking Machines > Fadal > VMC 15 XT fit in garage?
Results 1 to 7 of 7
    Feb 2009
    11
    So I've got a VMC 15 XT being delivered. But I've just now thought about the hieght of my ceiling and garage door header.
    My Ceiling is 8', 6"
    Header is 7'
    Can I take this apart to sneak it in? Is it going to fit under 8'6"? Anyone got one to measure up?
    How would you guys suggest moving these things around a garage?
    Apr 2005
    1194
    Yes Z axis motor comes off with 4 allen heads so you can easily slide it in. Make sure you mark your Z axis motor so you install it right or you may not get the right CS position. Slide it in and make sure you can get that Z axis motos on as some people have popped a small 5" hole in their ceilings...easily ran that way for sure!!
    We have had good luck with our Fadals milling mostly soft steel and aluminum up to 5 axis. We are always looking for spare parts If you have a broken down Fadal give a shout.
    Jan 2006
    64
    Not sure on that machine but you may also have to unbolt the flexible wireway at both ends and carefully lay it over to clear. These items are with the head all the way down as well. Had to do this with a 4020 and a 3016.
    900
    Hellpit--
    Here is the data for the VMC 15XT attached.
    Attached Files Attached Files
    Feb 2009
    11
    Thanks for the help guys.
    With the head/motor removed, does anyone know the height from base to the top of the cabinets?
    900
    Smile
    Hellpit: try these dims out for size.
    Neal
    Feb 2009
    11
    Quote Originally Posted by Neal View Post
    Neal
    Thanks Neal, exactly what I was looking for. I shouldn't have an issue getting her in with the motor removed.
    I think I'm going to get a bunch of 1/2" round bar cut to roll it around into place.
  1. What's in this Garage..??
    By Ridgeback in forum Bridgeport / Hardinge Mills
    Last Post: 10-22-2008, 05:18 AM
  2. Squeezing a VM-1 under a garage door?
    By rustyolddo in forum HURCO
    Last Post: 10-19-2008, 03:41 AM
  3. Fitting a Mill into a 2 car garage
    By heepofajeep in forum Uncategorised MetalWorking Machines
    Last Post: 11-16-2007, 02:15 PM
  4. Garage flooring suggestions?
    By jderou in forum Community Club House
    Last Post: 10-10-2006, 03:32 AM
  5. 80/20 garage sale machine?
    By groomden in forum DIY CNC Router Table Machines
    Last Post: 01-26-2006, 11:42 PM
