586,693 active members*
2,906 visitors online*
IndustryArena Forum > CAM Software > Mastercam > Machining time estimate ?
Results 1 to 3 of 3
    Jun 2008
    475
    I had found in MCX where it showed the estimated machining time and I don't remember where it was I found it.
    Would one of you remind me where that's at ?
    Thank you,
    Steve
    Dec 2008
    3112
    Time estimate
    -Select the operations you want
    -Backplot
    -upper LH corner ( the blue double arrows ) pull down
    -"Info" tab is the place to be
    Steve
    Jun 2008
    475
    EXCELLENT, THANK YOU !
    I did the backplot thing a couple of times while looking for it but I didn't click the blue dbl arrows.
    Thanks again, I really appreciate it,
    Steve
  1. File property under Axis- machining time estimate
    By Zig in forum LinuxCNC (formerly EMC2)
    Last Post: 07-31-2009, 10:44 PM
  2. V23 run time estimate?
    By cut more in forum BobCad-Cam
    Last Post: 05-08-2009, 07:40 PM
  3. Beta Run time estimate
    By barbter in forum NCPlot G-Code editor / backplotter
    Last Post: 05-30-2008, 12:31 PM
  4. dry run's time estimate ?
    By lepton in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 07-03-2006, 12:02 AM
  5. operation time estimate in setup sheet ?
    By andy55 in forum Mastercam
    Last Post: 10-06-2005, 06:14 PM
