We did purchased last week a used Moriseiki cnclathe. I installed it start working nicely.
But the problem know the feed rate is not changing by the G01 X...F.. command. what ever the F.. command the feed rate shows 200mm/min on screen.
We can be reduce by feed override switch when program is running.
Even we program F rate 0.05mm or 5000mm/min feed on display shows 200mm/min.
Please suggest which parameter ....? or any otherthings i need to look for...?
Thanks in advance.
Dinesh
