586,565 active members*
3,785 visitors online*
IndustryArena Forum > MetalWorking Machines > Hardinge Lathes > Hardinge Conquest Twin Turn 65
    Jan 2009
    6
    Been having troubles with the main spindle collets sticking when trying to feed material out to a stock stop. When you take the collet out there are burn marks on the angles portion of the collet. I clean the collet up and it works fine for about 10 minutes and it will start doing it again. I f you slap some grease in around the collet it might work good for a few hours tops. Anyone have any suggestions?
    May 2007
    1003
    Never heard of such a thing. Don't see how it could be possible unless the collet is turning separately from the spindle. This should be impossible because the spindle has a pin that must fit in the collet's keyway in order to be tightened. You must be missing the pin or it has been buggered up to the point it is no longer long enough to fit in the keyway.
    EDIT: I assumed you were running 16C or 20C collets. Not familiar with that model. We are running 6 Hardinge barfeeds. Got the first one about 20 years ago. None are Twin spindles, tho. Did you order it with different collets? Or does it come with different collets than the two I mentioned? We have a Nakamura TW20 that uses B42 collets. There is no keyway on these. However, we have never experienced the problem you describe. No keyway sure makes it hard to automatically load a new bar of hex material.
    Jan 2009
    6
    the burn marks dont appear to be from the collet spinning in the main spindle, looks like from colloet moving in and out. They key ways are in tact.
    Jun 2004
    84
    Quote Originally Posted by Jeff_Mezzo View Post
    Grind a small X over the burn marks with a thin cutoff wheel , then use lipstick. I've been doing this for 35 years for all my screw machines.
  1. M-code for Hardinge Conquest 42
    By b23 in forum Fanuc
    Last Post: 02-18-2009, 03:53 PM
  2. hardinge conquest 51 problem
    By bassmastrbw96 in forum Hardinge Lathes
    Last Post: 09-05-2008, 02:39 AM
  3. Hardinge Conquest 42
    By cncdiag in forum Fanuc
    Last Post: 05-21-2008, 01:06 AM
  4. Hardinge Conquest won't home?
    By Jim Wilson in forum Uncategorised MetalWorking Machines
    Last Post: 11-02-2007, 05:44 AM
  5. Training on Hardinge conquest t-51
    By mailloux in forum MetalWork Discussion
    Last Post: 09-20-2007, 08:58 PM
