586,905 active members*
2,731 visitors online*
    Oct 2006
    735
    Servo adapter spacers
    Hello...
    I know I've seen them but can't find the site now.. In anycase looking to adapt the .5" output shaft of one of my servo motors to a female coupler (that goes into a planetary)..
    In anycase I've seen them around, sorta like a collet with a split so it can be compressed and such..
    In anycase I'm sure someone can direct.. Basicly want to adapt a .5 shaft to a .75 clamping coupler and clamp them all together.
    Perhaps not the best soloution but want to be prepaired to do it this way as I don't think I'm going to be luckey enough to find a planetary gear head with a .5" input this time around. Most seem bigger then that these days.
    b.
    Jan 2006
    357
    I don't see a size on it but you could check these out
    http://www.kelinginc.net/CNCGEARBOX.html
    Oct 2006
    735
    I pretty much have chosen the planetary. since I've had good luck with my thomson I'll be sticking with that brand unit..
    In anycase just looing for shaft spacers to adapt the motor shaft to a larger size.
    ones I've seen have a split in them to alow for compression and such.
    Just another one of those great web site things where I can no longer remember where I saw them.
    b.
    Oct 2006
    735
    Here is a pic of what I'm looking for although this isn't the correct dim's..
    Anyway still in search of the page/ company.. Had a list of many different combo's of ID and OD's...
    b.
    Apr 2004
    44
    It's been a few years, but last time I checked, You could purchase these
    "Input Hub Sleeves" from Danaher Motion for about $25.00 each.
    They can be reached at: 1-540-633-3400
    Hope this helps.
    Oct 2006
    735
    I sent some mail to my contact there today so perhaps they will get back. I've contacted Thomson (Danaher) a few times in the past to get part number info and they have always been very friendly.
    b.
  1. 6061 SPACERS
    By EDPACECAR in forum Employment Opportunity
    Last Post: 06-03-2009, 04:43 PM
  2. spacers for project
    By spydermeister in forum Employment Opportunity
    Last Post: 05-30-2008, 01:00 AM
  3. NSK Rails - Replacement balls and spacers?
    By Lionclaw in forum Linear and Rotary Motion
    Last Post: 02-24-2007, 08:36 PM
  4. 47mm bearing spacers
    By N4NV in forum Linear and Rotary Motion
    Last Post: 02-06-2007, 02:40 PM
  5. RFQ - Aluminum plate and spacers
    By tjstraz in forum Employment Opportunity
    Last Post: 01-27-2005, 03:25 AM
