586,385 active members*
3,286 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > What to use as tinted cover for 7 segment display?
    Nov 2004
    44
    I have a project that uses three, 7 segment displays and I have this mounted in a nice thin CNC'd box. I need somthing as a tinted cover over the digits, something like the pro's use. I have tried using 1/16" transparent bronze acrylic sheeting, which looks great, but is a bit to thick. I cannot source any thinner than .060" so I guess thats out. I need something thats under .030, but not flimsy like window tinting( I tried this but its doent look nice). I just need some kind of stiff plastic film thats tinted so I can drop it in the pocket before I put the display in. Know what I mean? Any ideas as to what I should use or where I might source it?
    Thanks all.
    Jason
    24223
    It depend on what colour the LED's are as to what tint you use, there are nice bezels for this that should still be available, these have mounting frame and all.
    Al.
    Jan 2004
    668
    If you're into diy, you can spray a coat of Tamyia clear green, or charcoal, onto a thin piece of clear styrene .015"
    Jan 2006
    2985
    What about 35mm film? That big enough?
    Matt
    24223
    If you do not want to splurge on the bezel, for $2.00 you can get the real thing in a few colour tints.
    http://search.digikey.com/scripts/Dk...ed%20bezel
    Al.
  1. Replies: 3
    Last Post: 03-26-2010, 02:09 PM
  2. Sinumeric 840D - 7 segment LED
    By Cleverel in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 06-25-2009, 12:45 PM
  3. 16F84 7 segment display
    By Razer in forum PIC Programing / Design
    Last Post: 06-10-2009, 05:27 PM
  4. Replies: 5
    Last Post: 10-02-2008, 04:28 PM
  5. Mold material for tinted PC (Makrolon)
    By GalaticDan in forum Moldmaking
    Last Post: 02-21-2006, 02:28 AM
