587,065 active members*
3,764 visitors online*
Results 1 to 20 of 21
    Aug 2009
    7
    Mitsubishi Meldas 300
    i have a problem with our machine, control :
    Mitsubishi Meldas 300 (LATHE)
    battery is empty , and i need to exchange the battery, (how, and how many batteries ??)
    i need to know the procedure of reload the PLC and NC parameters to run the machine again. is it able to reloaded from itself or i have to enter it manually from the screen
    i have no operating manuals , no alarm list, no parameters. also appears the following alarms
    Z07 CRC ERROR 00F0
    502 INIT PARAM ERR-9
    405 INIT PARAM ERR-2
    EMG STOP B020
    ((( MITSUBISHI NUMERICAL CONTROL SYSTEM MODEL: FCA C3-S)))
    any help would be much appreciated
    Oct 2005
    672
    You must use nickel cadmium batteries. Do not use nickel metal hydrides. Do not use lithium. Using the NMh or Li batteries will destroy the charging circuit in the control.
    You can use any NiCd battery as long as you have 3.6V and a minimum of 250mAh. The higher the mAh rating of the battery, the longer the machine can remain powered off without losing parameters. If you are willing to be creative about the mounting, you can use the rechargable batteries for a cordless telephone. Mitsubishi wants a lot of money for replacements. For example, you can use batteries like these with a little creative installation.
    When you get the battery installed, you need to leave the control powered up for at least 24 hours to get the battery charged.
    To re-initialize the machine:
    Initialize the MC-161 card:
    - In the back cabinet, find the MC-161 card on the control.
    - Locate the DIP switches along the edge of the MC-161 card.
    - Starting from the topmost switch, flip the first, third, and fifth switches on.
    - Turn on the main disconnect, then turn on the control for 30 seconds.
    - Power everything off and set all the DIP switches back to the left/off positions,
    - Power up the control again. There may still be alarms because the process is not complete.
    Format the memory and load the canned cycles:
    - Go to the ALARM/DIAG screen and press the soft key for PLC-I/F.
    - At the bottom of the screen in the first three fields, enter 1001 in the DEVICE field, leave DATA empty, and M in MODE and press input.
    - Go to the TOOL/PARAM screen, and press the soft key for BASE2
    - Change fix_P to have a value of 1.
    - Go to PROGRAM/ IN/OUT screen.
    - Press the soft key IN/OUT at the bottom of the screen.
    - Press the soft key for ERASE.
    - In the DATA field, type FORMAT and press input.
    - Press the soft key INPUT.
    - In the #( ) field, enter 4 and press the input key to reload the canned/fixed cycles.
    - Power off the control, then power on again.
    Next, the machine parameters must be loaded. Hopefully, you have these parameters saved to your PC. If you do not have the parameter file, you may have to contact the machien tool builder. Set I/O parameters to transfer machine parameter file:
    - Go to TOOL/PARAM screen
    - Use NEXT soft key twice to show I/O PARAM and press the soft key for it.
    - On the first screen, find DATA IN, DATA OUT, and NC RUNNING. Set them all the same for now. Set DEVICE to 0. Set PORT to 0 if you're using the connector on the back cabinet or set PORT to 1 if using the port on the side of the front console.
    - Press the soft key NEXT to get to page 2/5.
    - There are three fields to enter data. The first is for the DEVICE you are communicating with (in case you want to use different settings for simple transfer and DNC modes), the second field is the parameter #, and the last is the value of the parameter.
    - Set my machines with the following:
    - These settings will run 9600 baud, 7 data bits, even parity, and 2 stop bits.
    Code:
    DEVICE NAME XON
    BAUD RATE 1
    STOP BIT 3
    PARITY EFF 0
    EVEN PARITY 0
    CR. LENGTH 0
    TERM TYPE 0
    TERM CODE1 0
    TERM CODE2 0
    REWIND CODE 0
    HANDSHAKE 3
    DC CODE PARITY 1
    Transfer the parameter file to the machine
    - Get your PC ready to transfer.
    - Go to PROGRAM/IN/OUT and press the soft key IN/OUT.
    - Press the soft key for INPUT.
    - In the # ( ) field, enter 3 and then cursor over to the DATA field. Leave it blank and press the input key. If the PC is ready and the RS-232 cable is correctly wired, the control will be waiting for data.
    - Go back to the PC and initiate the transfer.
    - When all the data is in, press RESET.
    - Power off the control, then power off the main disconnect.
    - Wait about 5 seconds and power the machine back up.
    Aug 2009
    7
    Dear Mr. Capriris
    thanks a lot for your help,
    i will do all the peocedures till ((download the parameters)) but i need to load the parameters manually. coz i have no cables, software or floby for the machine,
    could you please send how to download the parameters manually.
    do i need to change any more setting after entering the parameters.?
    now, i try to get the parameters pdf file from any one had the same machine ((CYNB-400)).
    could you please send the operator manual and alarm list PDFs??
    thansk a lot for your support..
    Nov 2012
    31
    Dear Caprirs,
    excellent explanation!
    I have Nomura nn-160D Screw type Lathe with Meldas 310LN control.
    But I don't have its parameters neither hard nor soft.
    If you or any one else can provide, it would be great favour.
    Dear Hlabib, what machine do you have?
    Nov 2012
    31
    Fellows,
    It is about an year ago when I wrote my last post to request dear members of this forum the parameters of machines Nomura NN160D.
    Since then the machines (two) are standing as rock on the floor.
    Please if any one have pdf / hand written / other version of the parameters please share it with me (free or at cost) at: [email protected]
    regards
    Jawad
    Aug 2007
    793
    Re: Mitsubishi Meldas 300
    hi guys
    why on one type of meldas 300 switches 1, 3, 5 work, but on another work the combination of 1 and 3 only?
    I faced with that problems
    Oct 2010
    6
    Hi Jawad,
    I have two Nomuras NN16H and NN16BII. Please find attached the list of parameters for both machines and just in case, mailed both to your address.
    Hope it works.Good luck.
    Feb 2016
    6
    Do any of you guys know how to Change Meldas 310 from Japanese to english? Also where can I get operator manual for Leadwell TDC-450 with Meldas 310 control? Thanks in advance.
    Aug 2007
    793
    file below
    BTW there are a lot of usefull files on meau.com
    Feb 2016
    6
    Thanks Guhl. I now have the operators manual for it from meau.com
    Sep 2017
    hi how i can change the language of the alemnd in english
    Sep 2017
    hello i have a alarm "A103 thermokompensation at traub 42 system TX 8F meldas 300
    Jul 2016
    108
    Hi there
    What I want to ask is about:
    Replacing the MitsubisheMeldas 300 Spindle Servo Motor With a Delta C2000 One.
    Is It Possible?
    Regards Russell
    Feb 2007
    23
    Do you have the link to get a copy?
    Jul 2016
    108
    Dear Marco, Could you explain what is your mean?
    Regards :-)
    Oct 2006
    222
    Is the L3 programming manual available anywhere?
    Apr 2019
    hello
    i have an traub tnm42, and i had same battery problem.
    I am user on this tool, and my service experience is beginner.
    i initialized mc-161 card, and i am bloked at the formatting procedure.
    I followed the procedure until the step:
    "Go to PROGRAM/ IN/OUT screen."
    I cant find "program" "in/out" and "erase" soft key.
    I attached a picture with what i have in my "IN/OUT" button menu.
    please help
    thanks
    Jun 2019
    hello i have a problem in my mitsubishi meldas l0 showing this message on the board: GX04 CARD (#2) NOTHING.
    Thanks for helping me.
    Jun 2019
    Mitsubishi Meldas M0
    Hello i have a problem in my mitsubishi meldas l0 showing this message on the board: GX04 CARD (#2) NOTHING.
    May 2019
    7
    Hello good afternoon
    Someone has the method of sending the files through the floppy, I only have the floppy disk of my computer's parameters, but I can't find its floppy so I have no idea where it is connected or where it goes or someone would help me,
    [email protected]
    thanks
  1. Mitsubishi Meldas 300-V
    By firestaromega in forum Computers / Desktops / Networking
    Last Post: 10-03-2023, 08:00 AM
  2. Meldas L3 - Mitsubishi
    By tomasz987 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 05-10-2023, 04:52 PM
  3. Mitsubishi Meldas 60S
    By BKCOM in forum Mitsubishi controls
    Last Post: 11-28-2016, 03:59 PM
  4. Need help with Mitsubishi CNC MELDAS C64, will pay $1k
    By YesNoMayBe in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 03-22-2012, 06:59 AM
