how to setup mach3 mill running Y axis with 2 stepper motor + 2 ballscrews?
Set up the second as A, B, or C axis. Make sure all settings are the same (except pins). Go to Config > Slaving and assign the slaved axis to Y.
Gerry
UCCNC 2017 Screenset
Mach3 2010 Screenset
Thanks ger21!
just curious how did those people do it with 6th axis using 2 ballscrews n 2 motors on Y axis ? parallel port only have 12 outputs
You can use two ports.
Gerry
I got d same problem and my second motor still not working though already Config > Slaving and assign the slaved axis to Y. Anybody knows how to set d others with relevant of slaving d same axis.
4 ur info I'm using 4 axis TB6560 driver board.
