587,019 active members*
3,998 visitors online*
Results 1 to 5 of 5
    Jan 2009
    7
    Not returning to zero/cummulative error
    I made router approx. 600x600x200 (mm) with servos and geckodrives g 320. Encoders have 500 lines.
    I use mach3 as control software.
    After milling I try to return to zero and every time I get error +0.5...+2mm on each axis (It depends on size of part, bigger part-bigger error).
    For the same part I have the same error every time.
    I don't use breakout board. I tryed breakout board, but the result was the same.
    It's not mechanical problem. I have double checked everything. I see error by marks on my pulleys.
    Please help me. I tryed everything and still don't know what to do.
    Jan 2009
    7
    Problem solved!
    I have solved the problem!
    There were some Outputs assigned to step pins. After disabling these outputs system works perfectly!
    Jul 2008
    35
    Quote Originally Posted by Gene1982 View Post
    Gene,
    I am having a similar problem. I am not sure what you are referring to here when you discuss the cause of the problem. Do you remember enough to tell me more about what you mean by "outputs assigned to step pins"?
    Thanks,
    Scott Kelley
    35538
    Go to Ports and Pins >Output pins and see if any outputs are assigned to the same pins as the motors.
    Gerry
    UCCNC 2017 Screenset
    Mach3 2010 Screenset
    Jul 2008
    35
    You had my hopes up - unfortunately that wasn't the issue - nothing else set for those pins. Thanks for the reply.
  1. Mach3 axis not returning to home
    By saltybugger in forum Machines running Mach Software
    Last Post: 01-18-2010, 06:57 PM
  2. Replies: 0
    Last Post: 10-08-2008, 02:43 PM
  3. Returning a new machine.
    By SIG in forum Uncategorised MetalWorking Machines
    Last Post: 02-20-2008, 08:27 PM
  4. Replies: 0
    Last Post: 12-12-2007, 12:05 PM
  5. Returning to 0,0,0
    By planekrazie in forum Mach Mill
    Last Post: 07-19-2007, 11:28 PM
