586,149 active members*
3,594 visitors online*
IndustryArena Forum > Other Machines > Engraving Machines > Laser Engraver Leaving Streaks when Engraving Mirrors! Any Suggestions?
    Nov 2004
    27
    Hello all,
    I just got comfortable running my new Laser Engraver. I started Engraving the back side of mirrors. The first few turned out very nice. I'm starting to have a problem with streaking. You can see by the pictures that I am posting below. Something is wrong! I'm not sure if it's my settings or what! All of the optics are clean! My focal length is correct as far as I know. The only thing that I can think of next is maybe doing a beam alignment, But I don't have the tool that was supposed to come with the machine. I've contacted the Manufacturer of this machine, and although I have gotten several responses from them in the past, No response yet regarding this issue. Any help would be greatly appreciated.
    Nov 2008
    Working with mirrors can be a real pain. Inconsistent "coating" thickness is one of the biggest challenges I've found so far. In fact I don't like to do mirror work for just this reason.
    I don't believe it's an alignment issue but one never knows.. What machine are you working with?
    Are you running this dry or are you using the wet paper mask? I know I had streaking/edging issues where the paper dried when I failed to keep it consistently wet.
    Barry
  1. got Dahlgren engraver for retrofit- suggestions?
    By lkasdorf in forum DIY CNC Router Table Machines
    Last Post: 09-14-2015, 03:15 PM
  2. engraving mirrors
    By denbruno_09 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-19-2013, 04:11 AM
  3. streaks on laser engraved image
    By identilase in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-29-2011, 08:37 AM
  4. CNC Laser Engraver, CNC Laser Cutting Machine, Dealer Wanted!!!
    By oliver9866 in forum Engraving Machines
    Last Post: 12-15-2010, 09:44 PM
  5. Suggestions for laser engraver around $4000
    By TacPyro in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-05-2009, 12:21 AM
