586,724 active members*
3,699 visitors online*
    Aug 2006
    133
    Replacing a stepper motor?
    I have a problem that I need your help with. I have a Keling Technologies KL23HM276-30-8B Stepper motor that I need to replace (The shaft broke). I need a direct replacement, so I don't have to change the set up on the controllers, because I have no clue how to do that. I have searched for a week trying to find someone that sells this model # and can not find it. Keling Technologies now has the same model number without the M character. I contacted them, and they informed me it was the same motor, but it was at 1.8 degrees instead of something else (what does that even mean). The man I spoke with was difficult to understand. My question is will this work? Are there other manufacturers which would offer a direct replacement? What are the performance characteristics that I should look for? Please Help.
    Apr 2008
    51
    1.8 degree step= how much the shaft rotates per pulse. 1.8 degrees out of 360.....
    And yes that keling stepper will replace the keling. as far as the M, I have no idea what that means. hopefully all of the colored wire will be identical for you. I always keep the wiring diagrams, just in case.
    Aug 2006
    133
    Thanks for responding.
    I just found a spec sheet on the one I have. It looks like the one I have has a .9 degree rating. Would that mean if I replace it with the 1.8 degree I would need to reset my software somehow to make up the difference? I am using Mach 3 to drive it.
    You'd need to reduce the steps/unit by half in the motor tuning screen.
    Aug 2006
    133
    That sounds easy enough, thanks.
  1. Replacing Spindle motor on stock Sherline
    By g29cc in forum Benchtop Machines
    Last Post: 06-08-2009, 02:22 AM
  2. Replacing motor and controller in plain X3
    By rashid11 in forum Benchtop Machines
    Last Post: 07-14-2008, 03:34 PM
  3. Replacing Spindle Motor on Prototrak type mill
    By mgb1974 in forum Uncategorised MetalWorking Machines
    Last Post: 07-02-2008, 12:29 PM
  4. Replacing stepper motor bearings?
    By acondit in forum Stepper Motors / Drives
    Last Post: 05-22-2007, 03:26 AM
  5. Tuning Bosch Drive cards when replacing SEM Motor
    By RMARCH in forum Bridgeport / Hardinge Mills
    Last Post: 03-03-2006, 06:34 PM
