586,655 active members*
4,170 visitors online*
IndustryArena Forum > CNC Plasma, EDM / Waterjet Machines > Waterjet General Topics > Plasma 4' X 4' "How much can you haul in a blue truck"
Results 1 to 3 of 3
    Jul 2009
    12
    First post, 4' X 4' cut size
    Hoping for some advise, with my plasma table ,i have looking at keling cnc packages 495 oz in 36v nema 23 ,I called them they could not tell me the torq curve for the motor wouldn,t that be the target RPM for gearing? I have also heard that running the motor to fast will lead to in accurate steps ,the other way the motor is sluggish They did say that speed is not HP . I would think that a table that runs a router would need to have alot more power than a plasma torch? I have the base built with a water cavity under the grids.I am leaning to rack and pinion on X and Y my x having a common shaft and drive both sides at once using 1 motor . Direct drive Z with a ball screw 12".My "Bridge" as i call it made from all aluminum .I also intend to use mach 3 if that matters.Any thoughts on the matter would be GREAT !!
    Jul 2005
    2415
    For R & P you gain speed (and give up resolution/accuracy and torque) based in the Diametric Pitch of the pinion times PI. So a 1" DP pinion gives you more than 3X the base RPM of the motor. That gives you speeds of up to 2400IPM. So you get speeds you can't use and give up acceleration and accuracy you can use.
    Transmissions do not create power (work) they just change what is on each side of the equation. On one side you have SPEED on the other TORQUE (acceleration) and RESOLUTION. Resolution is defined as the smallest distance you can move in one step. Resolution is not accuracy but is a component of it. Your accuracy is resolution times any other mechanical errors (backlash, flex, thermal expansion, etc).
    Rack and pinion for plasma is a valid choice. You have to deal with a lot of abrasive grit and precision screws don't fair well on the dirty environment of plasma. (neither do Laptops but that is another story!)
    The big problem with single motor drive shaft gantry designs is getting a consistent and good gear mesh with the rack. You have to fixed gears (pinion and rack) so the only way to adjust mesh it to move the rack into the fixed pinion. That requires you painstakingly go along the entire length of the rack and adjust it carefully into the fixed pinion.
    The design that solves both problems (driving each side and adjustable mesh) is the dual motor system with suspended type drive mounting. Each motor runs independently (but at exactly the same speed and distance) but having the pinion/belt transmission/motor assembly mounted on a pivot and pulled up into a firm mesh by a spring or cylinder. You no longer have to set each section of the rack for optimum mesh.
    When you look at a "kit" or package make sure it can be configured to meet the type cutting you intend to do. What kind of support will you get for your application (not just how to hook up the motors and make them spin). If your choice of control software is MACH do they have the in depth knowledge of that package to make their hardware work for plasma and or routing? Look at their manuals. Does it cover using the "kit" in your type cutting? How much hard wiring are you going to have to do? Will you have components others can help you with. A kit should be more than a bunch of parts thrown in a box. It's often a shock that doing plasma cutting correctly, is more complex and technical than most routing.
    The drive drive ballscrew for Z has some limitations. If you use too fine a thread you risk having a Z that will not function well as a THC. A 10 TPI leadscrew limits you to less than 100 IPM speeds on Z and under THC control that could fall to 30 IPM or less. That is fine for gently rising warps or on thicker material but if you have to cut a sharper rise you won't have the vertical speeds to do that and your THC response will be sluggish. If you use a two start leadscrew and get you actual TPI down to 5 or 4 then your speeds go up at least double.
    You need more torque at lower speeds (and a heavier stiffer gantry) for router. Accuracy is more important since you may have to make several passes and any offset or error becomes visible on straight edges.
    Unless you are looking for a pure learning experience (i.e you don't care how long it takes or how many "surprises" you get along the way) a package that is more completely engineered and integrated allows you to focus on the mechanical aspects of your build.
    Then there is the software side......:drowning:
    Jul 2009
    12
    Do you know of a good company for steppers? Not Keling
    Your right i have emailed keling 3 times asking for the torque curve of there nema 23 495 oz in 36v kit and all they do is answer other questions ,i even called and asked and the guy said there were to many variables i think they they don't know , I was referred to them buy a friend who has bought from them and was very happy. And yes it is a box if parts. I looked at another company who had a driver card and the motors plugged into it? I was looking at a 4 to 1 ratio over all compared to the rpm ? I think? I was inspired to build my own table after watching the PLASMA CAM video there id nothing high tech there other than when they cut there is no smoke ?
  1. "Which brand CNC plasma? I want a turnkey solution."
    By gibbonsm in forum Waterjet General Topics
    Last Post: 03-03-2009, 05:18 PM
  2. any experience with plasma "PIERCE RUR 2500"??
    By tibet in forum CNC Machining Centers
    Last Post: 03-29-2008, 09:48 AM
  3. Plasma "fine cut" accesories
    By carbidecraters in forum Waterjet General Topics
    Last Post: 09-16-2007, 02:47 AM
  4. Question on using "plasma" table for routing
    By Red Earth in forum Waterjet General Topics
    Last Post: 04-09-2007, 06:04 AM
