587,048 active members*
3,074 visitors online*
Results 1 to 20 of 21
    Jul 2009
    8
    Exclamation small Laser cutting and engraving machines
    Hi all, Am located in Singapore. I'm currently looking for a small laser machine that can cut and engrave designs on silver jewelry pieces. Is there any machines or company you can recommend me? Please help.
    Thanks alot.=)
    Dec 2008
    1258
    A Yb fiber laser or Q-switched DPSS would be ideal for this, but expensive.
    http://www.cmslaser.com/low-cost-fib...rking-machine/
    http://www.alphalas.com/products/las...FQIyxwodCFoLzg
    http://boston.kijiji.com/c-For-sale-...AdIdZ141038697
    There are some small desktop units designed for jewelry (above link, $21k is the cheaper end), but unless you need laser the much cheaper alternative would be micro CNC engraving.
    Zax.
    Jul 2009
    8
    thanks for your reply.
    but can micro cnc be able to cut the designs out?
    Dec 2008
    1258
    It depends on the size and thickness of material and the availability of micro end-mills. Laser would be faster and perhaps able to produce more intricate designs but at a cost.
    Zax.
    Jul 2009
    8
    ok..am looking for 1 for a small retail shop actually.
    Dec 2008
    1258
    Take a look at these options, gravo have lasers as well as rotary systems:
    http://www.gravograph.com/english/engraving-machines/
    http://www.xenetech.com/viperje_overview.asp
    I would suggest one of the small desktop CNC mills, specifically designed for jewelry.
    The startup costs would be much less and you should be able to get 95% of the same product out.
    You could then look at 'upgrading' to a laser later.
    Zax.
    Jul 2009
    8
    Quote Originally Posted by zax15uk View Post
    Zax.
    according to the video shown, there seems to be too much material wastage. if otherwise pls advise. but anyway thanks for all the advice and information =)
    Dec 2008
    1258
    That depends on how you setup the job, it is fairly typical for manufacturer demos to waste material. The person creating the job isn't paying for the raw materials.
    You will learn how to maximize profits. The waste from either a laser or router/mill would be similar, with laser typically being less.
    Zax.
    Jul 2009
    8
    hmm alright then thanks.
    currently found a souce that can engrave and cut metals from a china based company.
    http://www.cnc-laser-cutter.com/Minicncrouter.html
    is it any good?
    Jul 2008
    776
    BAD, I think
    I didn't trust to chinese companies who produce everything - from inkjet to laser. Really it means that these companies just resell this items without reliable service support.
    Please understood that you want work with silver and other jewellry materials. Price of mistake is too big, so for you will be better choose reliable and stabile US made equipment. USD dollar exchange rate is also favourable to US manufacturers ( in comparison with us :drowning: )
    Jul 2009
    8
    oh no...any US company to intro then?
    cause I emailed a coupled and none reply me
    Jul 2008
    776
    I also can agree with Zax about
    For you it will be best solution. Best way is send e-mail and call after to have confirmation that you e-mail is received.
    With Xenetech I have some problems but
    1) it was with lasers
    2) was over 8 years ago
    Jul 2009
    8
    can engraving machine cut through the metal as well? if say the thickness is about 2mm?
    Jul 2008
    776
    I hope Gravograph can cut up to 2 mm, but better speak with their managers or with happy owners. If you will work with relatively SOFT metals like silver,gold and etc - I see no problems with cutting if proper tool ir proper settings are used.
    OFF - my 100 message on this forum
    Jul 2009
    8
    thanks for ur advice, have emailed them & waiting for a reply.
    & congrats on ur 100th post in the forum. =)
    Mar 2009
    Hi, for more questions about laser machine, CNC Router, Cutting plotter, please feel free contact me at [email protected]
    Aug 2009
    4
    don't make false comment to the product of our country
    you just have wrong attitude to our product, i support our product.
    Jul 2008
    776
    primoyu - nothing personal, just business I have degree in mechanic and working with lasers since 1992 and I CAN'T BELIEVE that your company is manufacturing everything - from solvent printers to lasers.
    And as you can see - I never said that CHINESE PRODUCTS ARE BAD.
    Aug 2009
    4
    may be you are right
    i am not in the company that you think, i am a salesman in shenzhen china, but whatever,you may be right,it cannot manufacture everything.
    Jan 2008
    laser cutting machine for jewelry
    I'm working with Laser Cutting machines for jewelry about 8 years. I use this SISMA HomePage
    If you need more information [email protected]
  1. laser engraving & cutting machines / factory
    By mandyfang in forum News Announcements
    Last Post: 12-03-2010, 03:17 AM
  2. laser engraving machines
    By MBG in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 02-22-2009, 08:34 PM
  3. Replies: 0
    Last Post: 10-17-2008, 04:17 PM
  4. Laser cutting machines
    By blue^ray in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 03-14-2008, 11:24 PM
  5. Engraving photographs with CO2 Chinese laser machines?
    By GDP in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 08-20-2007, 02:01 AM
