586,652 active members*
3,020 visitors online*
    Jan 2009
    15
    Z-axis setup/control in Mach3
    Hello,
    I have made my own 3-axis engraving machine from scratch and have everything running well, but I need help with the Z-axis setup. I have only used the ports/pins and the homing/limits to set the direction and homing. I want to set z-axis home to the up position but the co-ordinates are working in reverse. How do I setup the z-axis ?.
    Cheers,
    Brett.
    Do you want to reverse the direction it's moving? If so, check "Reverse" in the Homing/Limits page.
    Jan 2009
    15
    Hi Gerry,
    Zeroing the z-axis to the bottom switch would seem the way to go, but when I have a tool in the spindle it will hit the machine table before the bottom limit switch !. My problem is more about how the z-axis needs to be setup more than how to reverse settings.
    Cheers,
    Brett.
    Typically you home the Z to the top of it's travel, and zero it to the surface of the part before running your programs. You might want to look into making an Auto Zero device.
    http://www.cnczone.com/forums/showthread.php?t=36099
    Jan 2012
    Z AXIS WILL NOT HOME
    HI THERE CAN ANYBODY HELP ME
    MY MACHINE WILL HOME THE X AND Y AXIS BUT I RECENTLY PUT A SWITCH ON THE TOP OF Z AXIS AND IT WILL NOT HOME, WONT DO ANYTHING AND THEY ARE ALL WIRED THE THE SAME THE OTHER 2 HOME PERFECTLY
    I AM USING MACH 3
    DARREN
  1. Mach3 A axis (4th axis) setup?
    By cadcamslawek in forum Mach Software (ArtSoft software)
    Last Post: 01-18-2012, 03:23 AM
  2. Mach3 R3.00 Mill 4 axis Foam cutter setup
    By Andy Smith in forum Mach Mill
    Last Post: 01-25-2008, 02:19 PM
  3. Featurecam Lathe Setup X axis MAch3
    By whiteriver in forum FeatureCAM CAD/CAM
    Last Post: 02-21-2006, 12:04 AM
