586,850 active members*
2,372 visitors online*
Results 1 to 7 of 7
    Feb 2005
    8
    Question High speed rotary coolant coupling
    I am looking for a source for a high speed rotary coupling that will handle 35,000 rpm.
    thanks
    camme
    Nov 2003
    459
    I'd like to find a solution for attaching coolant to a high speed spindle as well...
    There are a lot of things to be conserned about though.
    Pressure, RPM, syntrifcal force...
    I wonder at what point coolant that is pumped through a rotating spindle would just spin off laterally because of syntrifical force? If it did, it would not reach to cut zone...
    Interesting,
    Scott_bob
    Jun 2004
    450
    Feb 2005
    8
    Question
    Dab,
    Thanks for the link. I look at these and they won't handle 35,000 rpm or 2000 psi coolant. Also the taper on this Okuma is a HSK 63F. It had a 25000 rpm rotary that wouldn't handle the high rpm.
    Again thanks,
    camme
    Feb 2005
    8
    Scott bob,
    The coolant is expelled thru an ER16 collet or the tool tip and at 2000 psi has no problem putting 8 gpm in the cut zone.
    Thanks for your reply,
    camme
    Mar 2004
    564
    I beilieve "Barco" makes rotary couplings that can handle the speed and pressure.
    They are costly, as they utilize two polished ceramic surfaces to make the seal.
    menomana
    Mar 2004
    564
    http://www.barcoseals.com/coolant.htm
    Actually they are only good to 1500 psi, 20,000 rpm.accordiing to the web site.
    menomana
  1. High Speed Spreadsheet
    By MachineSMM in forum Hard / High Speed Machining
    Last Post: 05-21-2014, 01:57 AM
  2. What is high speed machining
    By Klox in forum Hard / High Speed Machining
    Last Post: 04-11-2014, 05:13 AM
  3. High Speed Hard Milling
    Last Post: 03-28-2006, 01:31 AM
  4. What is high speed machining
    By johnm in forum Hard / High Speed Machining
    Last Post: 12-29-2004, 11:41 AM
  5. high speed rotary table?
    By jleiwig in forum Benchtop Machines
    Last Post: 11-18-2004, 04:39 AM
