586,379 active members*
3,043 visitors online*
Thread: G540 Wiring
    Aug 2006
    8
    G540 Wiring
    I currently have :
    * G540
    * KL-600-48 48V/12.5A
    * (3) KL23H286-20-8B (info sheet : http://www.kelinginc.net/KL23H286-20-08B.pdf)
    Do I want to wire these steppers in Bipolar Parallel?
    If so, what should be the impedance for the current set resistors on the G540? 2.8k ohm?
    -clamps
    Feb 2007
    4553
    Post
    Yes.
    If so, what should be the resistance for the current set resistors on the G540? 2.8k ohm?
    Yes.
    Patience and perseverance have a magical effect before which difficulties disappear and obstacles vanish.
    Aug 2006
    8
    Quote Originally Posted by jalessi View Post
    Yes.
    Yes.
    Thanks for the reply.
    To wire the motors Bipolar Parallel is this the correct wiring scheme? :
    Pin 6 => grn/wht + blk/wht
    Pin 7 => grn + blk
    Pin 8 => blu/wht + red/wht
    Pin 9 => blu + red
    Thanks again for the help.
    Feb 2007
    4553
    Post
    Pin 7 => grn + blk
    Pin 9 => blu + red
    Yes you are 100% correct, no need to worry,
    Jeff...
  1. G540 wiring diagram for dummies? :)
    By bkboggy in forum Gecko Drives
    Last Post: 08-28-2010, 07:45 PM
  2. Hot G540
    By jdemille in forum Gecko Drives
    Last Post: 05-08-2009, 06:40 PM
  3. Wiring diagram for Gecko g540 and cnc4pc C8 relay
    By blackrat in forum Gecko Drives
    Last Post: 04-25-2009, 11:22 AM
  4. can you... BOB to G540?
    By Fixittt in forum Gecko Drives
    Last Post: 01-28-2009, 01:37 PM
  5. G540 - WOW!
    By LaserImage in forum Gecko Drives
    Last Post: 12-04-2008, 10:30 PM
