hi everybody,
Despite of world wide crisis I started with my new mill I have planned and drawed during past 8 months.
5-axis.
Added sketsh (not all components are drawn).
This is composite mill - used massive Aluminium up to 80mm thick, machined artifact commercial granite panels. All gaps and emty places filled with composite-granite between thoses.
X-"walls" are 75mm thick (hight > 500mm), Y-bridge is machined from 650x210x78mm solid Aluminium, Z-axis made from 600x170x78mm solid Alu. There are no main parts thinner than 15mm Aluminium. Face U pate is 15mm thick aircraft aluminium ...
Stationar table surface is 650x630x30 pressed granite, total thickness of table 78mm. There are diamont cut holes though, there will be M8 hollow bronze plugs 80mm long ... 4/5 axles will come bit later, when main machine is ready. 4-th axis is 250mm wide, 80mm thick, 5-th axis table has 180mm diameter. For driving 5-th axis I use FA15/49 Cyclo drive (integrated in to ...), for 4-th axis I have FA35/109 - I hope to change this for smaller one ...
X,Y,Z axis uses ISEL 16/5 ballscrews with TWO zero backlash nuts for each.
X axis gas two sets of screws/touble nuts.
Z -> 2 rails 4 cars SHS20LV, Y -> 2 rails 4 cars HGW25CC, X -> 2 rails 4 cars HGH25HA. My first ATC spindle is also ready.
I already bought 5 x VCD-E (+5 servo motors) from www.granitedevices.fi .
Mach3 (15-350 Model) also ordered - hopefully next week I can touch it with my own hands.
http://www.machmotion.com/CNC-Contro...duct_info.html
http://www.machmotion.com//c30/p60/X...duct_info.html
Several parts are ready and I started with frame up. It will be very hard, but I hope ...
Im sure you wonder - why such kind of strange design ...
Yeah, but why to build separate screens and cabinets?
Herbert
