586,403 active members*
2,750 visitors online*
    Feb 2009
    6
    The Gecko 320 servo drive
    Will the Gecko 320 servo drive run the servos on a BP mill with the MT30r4-58
    servo motor or should I stay with the Bosch drives that came with the mill
    I am trying to upgrade the TNC 145 controler and go with a PC based Machine not sure what to do?
    Oct 2007
    24
    conversion
    Hi I did a Bridgeport with the origional servo motors and the 320s
    80 volt power supply works great. search some of the older Bridgort threads for some of my prior posts for more info.
    Doug
    Feb 2009
    6
    What break-out board did you use? I have a ton of questions to ask you I am
    not sure on what works with what and how to you know. I have about 1300.00 I can spend on getting this mill up and running. I just need to becareful
    on how I go. I have talked to John at Pico systems. I like him and the prices
    are good. Have you had any dealing with him?
  1. Gecko Drive
    By Don Kellogg in forum DIY CNC Router Table Machines
    Last Post: 08-10-2008, 06:12 PM
  2. 320 gecko drive
    By Ed Williams in forum Gecko Drives
    Last Post: 05-19-2008, 06:20 AM
  3. Possible Gecko Drive?
    By juzwuz in forum Gecko Drives
    Last Post: 03-19-2008, 05:00 PM
  4. Driving 160v servo from gecko drive
    By ahmedrehan in forum Gecko Drives
    Last Post: 10-07-2007, 03:05 AM
  5. Which Gecko Drive
    By Lloyd in forum Gecko Drives
    Last Post: 05-31-2006, 07:35 AM
