586,401 active members*
2,939 visitors online*
Results 1 to 8 of 8
    Feb 2005
    Post Connecting a Controller Board
    I had some problem related to connecting the stepper motors to the controller board.
    Can someone give me a solution on how i can connect the motors to the board.
    Secondly, can the 2nd generation board work with servo motors.
    The motors don't connect to the DeskCNC board. The DeskCNC board sends step and direction signal to motor drives, which can be either stepper or servo drives.
    Nov 2004
    139
    Can anyone explain the 'out I/0', 'Encoder', and 'in I/O', of the controller board?
    thx
    cs chang
    Nov 2004
    139
    Controller setup...open pdf
    Attached Files Attached Files
    270
    Quote Originally Posted by happytriger2000
    out I/O has the output connections. 7 relays and a PWM spindle speed control line.
    Encoder is for the input of quadrature signals from an incremental encoder. Used for spindle synchronization in lathe threading or for manual pulse generator.
    in I/O has the input connections for 4 home switches, limit/probe, e-stop, feed hold, and cycle start.
    Fred Smith - IMService
    http://www.cadcamcadcam.com
    72
    what is the cycle start input meant for ?
    I could not yet make out from any documentation, what the cycle start input on the 2nd, gen. DeskCNC controller board is for except to download a new firmware. Any additonal usage during CNC operation ?
    Dan
    270
    Cycle start is enabled on the Controller menu.
    http://www.cadcamcadcam.com/hobby
    72
    cycle start / cam lobe
    Fred Thanks a lot for your reply.
    How does it react ?
    does it have to be a connection to gnd. or +5V to start ?
    just on a pulse from a push button or does the switch have to be closed for the entire cycle ?
    Would appreciate If you could also have a look at another thread I just started today about cam lobe scanning on a 4th. axis.
    Thanks in advance
    Paraprop
  1. One controller board does it all?
    By Hack in forum CNC Machine Related Electronics
    Last Post: 03-07-2006, 10:51 AM
  2. Open Source CNC Controller Specification
    By gregmary in forum DIY CNC Router Table Machines
    Last Post: 12-05-2005, 04:58 AM
  3. Does anyone know of a controller board for synchronized stepper motors
    By Yellowbeard in forum Stepper Motors / Drives
    Last Post: 04-04-2005, 05:06 AM
  4. Looking for controller board for synchronized stepper motors
    By Yellowbeard in forum CNC Machine Related Electronics
    Last Post: 04-02-2005, 03:50 PM
  5. Controller board location
    By smitty in forum Benchtop Machines
    Last Post: 04-03-2003, 05:40 AM
