Am looking for a transformer for the hobbycnc board. Needs to be 230v input, 24Vac output, 10A. Am struggling to find any with enough power. Any UK people here founf anything?
Dear ted34,
RS do them at about £28 plus VAT.
http://docs-europe.electrocomponents...6b80027b48.pdf
Rated at 12 amps and 25 volts AC.
I can get you one if you want, without postage charges
Best wishes,
Martin
That be great - cheers Martin. Are you sure that transformer will work as its only 300Va if I connect the two secondarys together? Do you know if the 30 or 35V output version will give more power?
Please can you email me regarding getting one: e31ddie at hotmail.com
Dear ted34,
All 300VA transformers have the same power rating. If you increase the secondary voltage, the available current decreases. The 35 volts per secondary version can supply 8.6 amps when the secondaries are in parallel. The 25 volt version gives 12 amps.
Best wishes,
Martin
