587,168 active members*
3,169 visitors online*
IndustryArena Forum > MetalWorking Machines > Uncategorised MetalWorking Machines > Error 414 Z-axis error detect servo alarm
    Jan 2009
    6
    Exclamation Error 414 Z-axis error detect servo alarm
    I'm using a Hwacheon Ecomil 65V with Fanuc 18M brain. Upon startup, the oil cooling unit does not turn on as it normally should and I'm given an error "414 Z-axis error detect." I am not able to move the machine or start the spindle. I have had this problem before and have resolved it previously by filling the hydraulic oil reservoirs as they were low. The oil has been filled and the machine was running fine yesterday. Today the machine produced the error upon startup and the oil levels are all fine. Any ideas?? Thanks a lot
    Andrew
    Dec 2008
    239
    Question Z servo error
    please give the correct drive specs , Whereas you can check the signals by logic which are responsible to make drive enables , If the problem persists can call or communicate me on +91-9430737981 or on [email protected]
  1. 410 Alarm X axis ecess error
    By scuba in forum Fanuc
    Last Post: 02-19-2024, 07:39 PM
  2. 434 servo alarm: Z axis detect error
    By padobranac in forum Fanuc
    Last Post: 12-21-2021, 03:18 PM
  3. HAAS VF-2 (104 ALARM) Y SERVO ERROR TOO LARGE
    By joanpim in forum Haas Mills
    Last Post: 09-12-2011, 10:24 AM
  4. Help! alarm 414 X axis detect err
    By CVMW in forum Fanuc
    Last Post: 01-10-2009, 02:42 PM
  5. Replies: 4
    Last Post: 08-12-2008, 11:01 AM
