when transfering slug from h1 to h2 ,machine stops with no alarm right after the m11 code ,is there a way to bypass machine recognizin that collet is open on head 1
This site changed my life ----> www.alittlebiteasier.net
its in a collet
no bar stock, just slugs. I don't have a problem when i am using barstock
I should have thought of this before, because I've had the same problem. What I ended up doing was using a spring loaded collet stop, on the end of it I threaded a slug approximately the same diameter as the collet diameter. After pick up it would release the the spring tension and the slug would be sticking out of the collet about .100. Then simply re-clamp the collet. I'm sure there is a parameter code, I know you can go into the custom table and switch it so it won't alarm, but you'd have to switch it every time.
